Question about Plumbing
Removing the bottom impeller for a 390.25320 well pump, i have removed the nut that retains it?
It seems stuck I see nothing that holds it in place, I have tried to pry it off with 2 screwdrivers, any harder will destroy the impeller.
  • 126 Answers
SOURCE: Bissell 7950 ProHeat Self Propelled Carpet cleaner Replacement Pump Belt part 215-0628
Normally, there is a post sticking out of the retainer to remove it. If the post is broken off, then you will have to lift the black arm and wiggle it at the same time and the retainer will pop up so you can remove it. On the belt side, the retainer is fairly large and you can usually get a hold of it with a pair of needle nose pliers. On the other side, the retainer is small and you can lift it out with the pliers by griping it gently using the hole that the screw goes through.
Posted on Jan 27, 2008
  • 112 Answers
SOURCE: removing water pump impeller
you might have to split the case to get to the back side of the impeller.
Posted on Mar 29, 2009
  • 969 Answers
SOURCE: Pump noy pumping water
If it is a FLOTEC pump, 3/4 hp P/N: FP4122 or 1/2hp P/N: FP4112 you can get parts at: 1-800-365-6832, see flotecwater website.
Posted on Apr 30, 2009
SOURCE: Belt removal for Amana washer model#LWD70AW
u have to wiggle pump from side to side and up and down shoul losen up and pull strsight out
Posted on May 27, 2009
digritz
  • 530 Answers
SOURCE: 1990 f150 4x4 front axle removal
I'm not positive what type axle you have but the order of parts should be the anti lock free running hub assembly, a lock washer then the wheel bearing lock nut. The lock nut could look like a thick washer with 5 or 6 holes in it.
But depending on your front axle you may have a rotor and hub assembly that's a single unit or they could be separate. If they are separate then you may need a sledge hammer to get the rotors off. Ford's front rotors can be a real pain in the a$$ to get loose. Regardless which type you have if the order of what you have taken off so far matches what I said then washer is probably the locking nut. The only way to get it off is a special spanner wrench or a punch and hammer. If you are still uncertain about it let me know and give the axle make and type and I'll be glad to help.
Good luck
If
Posted on Sep 12, 2009
Remove pool pump motor jacuzzi magnum force
It may be easier to disconnect the power, depending on access. You can also remove the impeller, seal plate and mounting bracket. Which ever way is easier.
Nov 28, 2013 | Pool & Spa
Impeller
J5s is a back pull out. Remove the bolts holding the front casing to the motor. Remove the diffuser. The impeller will either be screwed on. ie the impeller is moulded with a thread, or key wayed .ie a separate metal nut holds down the Noryl impeller and a small piece of "key" steel keeps the impeller on the shaft.
Remove the rear fan cover, and either use a flat screw driver (if there is a slot in the rear of the shaft) or a shifter (if the shaft has a hex) or you may have to prise the fan off. to get a good hold of the shaft.
Hold the rear of the shaft, and with the correct socket undo the hex on the impeller. either the nut or the whole impeller will come off. If just the nut type. Use cable ties to thread down the centre of the impeller to the out side and join. do this in a couple of places.Use these as a lever point to pull off the impeller.
The seal just pulls off. there is two parts stationary and rotating.( 18th may, yourve probably worked it out by now)
May 18, 2013 | Goulds Pumps Goulds J5S Jet Pump Shallow...
I need to know how to tape the impeller off. i was told that i had to pull the pump apart in order to remove the impeller????
You do not supply much information, but yes, the impeller sits right inside a pump housing, Split the housing and the impeller is the vaned part that is attached to the shaft, the pump rear casing will have remained behind. The should be a nut holding the impeller in place and it may very well be a left hand threaded nut. Remove the nut and the impeller will come off with a little coaxing. Some impellers are press fitted and may need a puller to remove.
Jun 30, 2011 | Garden
Piece of glass dropped through the filter housing when cleaning. Now there is a sound like the motor is jammed.
Hi ghedinger,
Seems something is stuck on your drain motor, now to thoroughly clean the unit and part, do the following:
- Remove as much residual water as possible from the sump and drain hose.
- Open the door.
- Remove the bottom basket.
- Remove the bottom spray arm.
- Unscrew the bottom spray arm flange.
- Remove the filter combination.
- Lay the dishwasher on its back.
Now you will see the Drain pump, like so:
Now you need to remove the drain pump from the housing to clean it thoroughly:
- Disconnect the pump plug connections.
- Open the safety retainer clip with a screwdriver
- Turn the pump clockwise and pull it from its holder
Now clean the impeller area, and then re-fit everything (Remember: When refitting, apply a little water or soap solution to the pump seal as a slip lubricant.) Then Test
Hope this helps :-)
If you found this solution helpful, please rate accordingly
May 07, 2011 | Miele G2732SCIWHWH Dishwasher
I have a US!1102 AO Smith 1HP Pool Pump Motor. I was told to hold one end of the motor shaft and turn the Impeller clockwise to remove the impeller, I was told NOT to remove the nut at the center of the...
I have never taken this pump apart.
If I were in your position and I could move the impellar 1/8 turn, the next thing that I would do is carefully loosen the nut on the end of the shaft being careful that nothing else disassembles. Once this nut is loose say 2 turns, try the impellar again watching what is moving. It seems that the nut may have to be removed.
Also, I'm not sure which way the nut of the impellar rotates to remove, but you seem to have that under control since you have it moving already.
Gary
Feb 20, 2011 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Water works spa pump- need to remove wet end... through bolts are out, motor shaft is free, impeller is frozen in housing... impeller has no visible nut/bolt holding it on, is this press fit or other? how...
Most of these are reverse threaded. There should be a place on the shaft that is flat on 2 sides a 1/2" or 9/16" wrench will fit into the slots. If not look at the back for a place to use a hex key. Hold the wrench/ hex key stationary with the Impeller facing you turn clockwise.
I know this sounds backwards but it should work.
Hope this helps
Please leave feed back
Dec 01, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My Whirlpool quiet partner dishwasher seems to run
try a large cresent wrenck,or channel lock plier.ps.might place towel over plastic nut,to protect from wrench damage.
Oct 10, 2009 | Dishwashers
How to remove impeller from motor to replace. I 've removed all the bolts but can't remove the impeller from the shaft.
If it's a separate shaft, it requires a puller tool, but first you have to remove a nut that holds the impeller to the shaft. If the shaft is part of the impeller, meaning that it is a one piece fabrication, then there is nothing you can do about it. You haven't even stated where does this impeller come from, a washing machine, a water pump, etc.
Sep 18, 2009 | Jacuzzi Impeller, L - 3/4 H.P
Does not pump water during the wash cycle.
It sounds like you are on the right track.
Open the dishwasher, remove the bottom rack, then remove the thumb nut in the middle of the unit that secures the lower wash arm and housing. Look for debris and clear any you find. Try again. If no joy, you will have to repeat the first step and also remove the wash pump upper housing that is secured with torx head screws. Same thing after you remove it - look for debris in the impeller area and remove it.
If you have to remove the wash impeller, you will need a 1" offset box wrench and as I recall a 1/4" socket. The 1" offset box wrench is needed to keep the impeller from turning while you remove the center nut. You will also need to remove the upper discharge line retainer clip to get that out of your way. Inspect the impeller for any debris and especially cracks or missing blades. If the impeller is damaged it will need to be replaced.
While you have this thing apart, check the lower wash arm and upper wash arm discharge pipe assembling for any obstructions.
I am assuming the motor runs ok and the timing cycles seem normal.
May 03, 2009 | Dishwashers
Indesit dishwasher DV62
You have a blockage in your drain pump. Remove all filters and scoop out as much water as you can from the unit. Check in the bottom for any objects stuck there. Some models have a cover on the bottom inside the unit, which once removed, will expose the drain pump impeller. If yours does, remove the cover(usually 1 screw only) and free the drain pump impeller. NB: DO NOT REMOVE THE SCREWS WHICH HOLD THE BASE TUB IN PLACE! These are the screws on the edge of the white plastic "bowl" inside the unit. The drain pump cover will be INSIDE this bowl and will be quite small, no more than 5cm dia.... If this does not work, you will have to remove the drain pump from the bottom or front of the unit to get the blockage out. Oshie
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Plumbing Logo
41 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
