Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
WATER DISPENSER ON GALAXY SIDE BY SIDE REFRIGERATOR DOESN'T WORK
WATER DISPENSER DOESN'T WORK
  • Carol Cobler
    Carol Cobler Nov 27, 2013
    I was filling a water bottle and propped it up. It overflowed while I wasn't looking. when I pulled it off the water dispenser was not working any more. The valve is on and the icemaker is working fine. I don't know if backflow broke something. I feel really dumb for doing that, but we use a lot of water so I want to fix it.
    Scholar:
    New Friend:
  • 81 Answers
Sounds like if your ice maker is still working, you're having an issue with your filter maybe freezing. Check to make sure your water filter isn't froze. What you're talking about with the overflow is a coincidence, but unless the internal wiring for the unit inside of the dispenser got damaged, i doubt thats the reason why. It's either a frozen filter or bad water valve. Try dethawing the filter or taking it out and seeing how much pressure there is built up in it. There's also a water reservoir in the back of this unit that may be froze too.
Posted on Nov 28, 2013
2 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: Galaxy Side by Side Refrigerator water dispenser
Check the water valve in back of refrigerator and make sure it is working ok
Posted on Nov 15, 2007
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
Water dispenser problem
Bad damper in fridge side, causing water filter to freeze. Guess not making I've ether. Replace damper
May 05, 2013 | Refrigerators
I have two problems with the Kenmore Ultra side-by-side refrigerator I inherited with my new house. 1) Water and Ice Dispenser do not dispense. Ice is being made but doesn't come out and water...
check the switches inside the panel where water and ice come out. that front panel comes off. this happened to me those switches are mounted on plastic mine broke and I used zip ties to put them back in place. The switches were just dangling there.
Aug 04, 2011 | Kenmore 53642 / 53644 Side by Side...
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
May 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker is not working - not making ice - water dispenser is working fine
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
te95
Dec 07, 2009 | GALAXY Microsystems 25.4 cu. ft....
Refrigerator about 5 years old. stopped dispensing water twice in last 12 months. Ice and crushed ice works perfectly. No water for last 2 months. Whats up?
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Nov 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a leaky spigot what can I do
If the spigot means the end of the water tube in the water dispenser, and it steadily drips even if the dispenser is not used for 10 minutes or so - replace the water valve. If the dispenser drips water mostly wright after you used it - you might have some air bubbles in the refrigerator water tubing.
Oct 17, 2009 | GALAXY Microsystems 25.4 cu. ft....
Not making ice
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Sep 24, 2009 | GALAXY Microsystems 25.4 cu. ft....
Water line
That coil is the line to the water dispenser, and its purpose is to chill the water before dispensing it. The coil of tubing is better than a tank because it chills quickly, takes less space and doesn't hold stagnant water. It shouldn't have any effect on the icemaker.
Jul 26, 2008 | GALAXY Microsystems 25.4 cu. ft....
Nov 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
61 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
