Question about Dryers
Electrolux inspire 7kg automatic control model, EDC77570w keeps flashing E60 and it just dose not work, i cant find anything in the manual booklet, can anyone help????
4 Suggested Answers
  • 15 Answers
SOURCE: The padlock symbol keeps flashing on my edc77570w
The door lock switch is faulty.
Posted on Jun 28, 2009
protek480
  • 1714 Answers
SOURCE: Electrolux tumble dryer
Power it down and then restart. Turn breaker off
Posted on Aug 27, 2009
  • 3074 Answers
SOURCE: It comes on for 2
is it a sensor dry? is there damp washing in there when you are testing it?, or is it empty as this will tell the PCB to stop as it feels no moisture in the machine
Posted on Jan 16, 2011
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Feb 21, 2015 | Electrolux Washing Machines
Wiring on Electrolux Dryer terminal block
Do you have the wiring diagram pasted to the inside of the dryer somewhere, probably would tell you. Or maybe on line manual PDF
Jan 26, 2014 | Electrolux Dryers
Washing machine error
HOLD START AND SKIP TOGETHER AND TELL ME WHAT IT SAYS. Also give model and serial number.
Apr 25, 2013 | Washing Machines
I am getting an error code on my EW1080F cam you advise what it means or where to go to find out? Error code is E60.
Try the Electrolux troubleshooter tool on their website: http://www.electrolux.co.uk/Support/Troubleshooter/
I put your model number in, followed the steps, and for E60 it just says the programme has been interrupted - allow the machine to cool down for 30 minutes before restarting.
Feb 05, 2011 | Electrolux Washing Machines
It comes on for 2 mins and then E50 comes up on display,sorry its an Electrolux Inspire 7Kg Dryer.
Jan 16, 2011 | Dryers
E60 keeps flashing and beep noise. Machine is mid cycle and has come to complete stop
Electrolux E60 - NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED.
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or blocked or scaled up screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Nov 13, 2009 | Electrolux Washing Machines
Aug 27, 2009 | Dryers
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Dryers Logo
283 people viewed this question
Top Dryers Experts
