Question about Westinghouse LVM-42w2 Television
Westinghouse TW70022 (model EW32S5UV) will randomly stop mid-tivo show and go to the set-up wizard.
Westinghouse TW70022 (model EW32S5UV) will randomly stop showing a tivo show and go to the set-up wizard. Using the tv remote, I reset the options. The picture returns...wait.... for 5 minutes, or 20 minutes, or 1 minute, then goes back to the wizard. We've tried the "soft reset" of holding the power button on the tv. Still does it. Tried unplugging ALL wires twice - once keeping the power, the other disconnecting the power too... for hours.... Works fine for a short while, then the problem returns. We tried to update the firmware.... this fix lasted about a month. Any other suggestions? We're handy so willing to try anything. Notes: this tv isn't used often when it was working... only for 1.5 hrs in the morning... then occassionally at night for another 1-3 hours a few days a week. Now, it's a pretty fixture.
4 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: Picture clarity
Sounds heat circuit related, and if under warranty you should notify them before you have to pay for the tuner or sync board.
Posted on Feb 04, 2008
  • 13 Answers
SOURCE: Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Posted on Jan 22, 2010
  • 286 Answers
SOURCE: westinghouse ltv32w6hd power supply
One of two symptoms on this model (LTV-32W6HD) Blue light comes on but cannot shut off. No picture; OR No picture but sound is OK. 1: In both cases replace ALL the electrolytic capacitors onthe output side of the power supply. This should get the power switch to worknormally. 2: Replace the small tiny wee little tiny small 2.0A fuse onthe inverter board labeled F1. This is the small black fuse, not the slightly bigger whiteones labeled F2 and F3.Ta Da...all fixed.
Posted on Dec 20, 2010
Have lost manual what are the settings for a westinghouse 2 door fridge model rj5325r ?
usually they start mid range on the dial perhaps 4 then adjust as required later on
Nov 13, 2017 | Westinghouse Refrigerators
Tip
Play Tivo HD Videos on Motorola Droid X,TS Tivo to Droid X How to convert and...
How to convert and play TiVo shows on Motorola Droid X? To solve this problem, you need to transfer TiVo, TiVo HD shows to your PC and then convert them to Motorola Droid X MP4 format with Aunsoft Droid X Video Converter. With the recommended software, you can convert TiVo, TiVo HD, TS TiVo shows to Droid X mp4 by yourself fast and easily!
How to convert TiVo to Motorola Droid X MP4?
This guide includes 3 parts:
Parts 1: Transfer TiVo shows from TiVo DVR to PC
Parts 2: Convert TiVo to Motorola Droid X MP4.
Parts 3: Transfer converted TiVo shows to Droid X.
To transfer TiVo shows to PC, you need to download TiVo Desktop Software. When your TiVo is connected to your home network, TiVo Desktop provides you with a list of available shows for transferring to your PC.
After you transfer TiVo files to your PC, you can convert them to Droid X mp4 format. First of all, download TiVo to Droid X Converter and launch the application. Then follow the steps below:
Step 1: Import TiVo files to TiVo to Droid X Converter
Enter Media Access Key for your TiVo files from “Option” button and then load TiVo files to the TiVo to Droid X Converter.
Step 2: Edit TiVo files
Editing functions are available by clicking “Editor” button in the menu bar. You can crop, trim, add text/image/video watermarks, replace audio, add special effects, etc. you can check “Apply to all” to apply the present settings to all the TiVo files.
Step 3: Choose Motorola Droid X MP4 output format
After you finished editing, you then choose output format from “Format” drop-down list and specify the format Motorola Droid X H.264 Video (*.mp4) (recommended) under Android profile among the options.
Tip: The default resolution of output format H.264 MP4 is 480*320, if you don't like it, please click "Settings" to set the size (pixel) to 800*480 or 854*480, or you can custom the resolution if you wish to.
Step 4: Convert TiVo shows to Droid X MP4
Click “Convert” button to start converting TiVo to Droid X MP4. Check “Merge into one file” to join all TiVo files to one output Droid X mp4 file before start conversion.
After converting your TiVo shows to Droid X, you will get mp4 file(s) in destination folder. Then you can transfer your videos to Droid X for playing, if you have any problem on transferring files. Please read: Transfer or Copy Movies and Musics to Motorola Droid X.
Now you are free to enjoy your TiVo recordings on Droid X wherever you go.
on Aug 04, 2010 | Cell Phones
How do i get my tivo 652-160to stop recording tivo suggestions?
Go to: TiVo Central>>Messages & Settings>>Recording>>TiVo Suggestions, and press 'Select' "Do Not Record TiVo Suggestions"
Jan 18, 2016 | Tivo Televison & Video
Westinghouse Setup wizard
westinghouse will not work with an APPLE remote
Jun 09, 2013 | Westinghouse Televison & Video
Westinghouse LD2480 no set up wizard?
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 18, 2013 | Westinghouse Televison & Video
Machine stopped mid cycle. has power at wall, however power light does not show on washing machine
Hi just read your posting.To help you I need the model number, the name of the machine and If it is a front or top loader.Looking forward to your reply.
May 21, 2011 | Westinghouse Washing Machines
Can I record VHS tapes to my TiVo model TCD649080?
Sure, just plug the output of the VCR into the input on Tivo. Set the Tivo to Channel 0 or 1, hit play on the VCR and then Record button on Tivo. Stop recording when the tape (or portion of) is finished.
Mar 04, 2011 | Tivo Series2 TCD649080 Video Recorder
When my Tivo stops recording a show on, say, channel 54, instead of staying on channel 54 it switches to channel 5. In other words, it only gets ''part'' pf the channel number. This happens with other...
The end of the IR Cable that attaches to your cable box may have to be repositioned.
Try moving it a small distance (you are already close or you wouln't be receiving ANY channel changing info. from it) and see if that helps.
Sep 12, 2009 | Tivo Series2 TCD649080 Video Recorder
Problems with DVD/VCR Player and Tivo
How are you attempting to connect this? Can we get more information, such as your TIVO model and TV model?
Jan 13, 2007 | Zenith ZRY-316 Video Recorder
Westinghouse LVM-42w2 Television Logo
29 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
