Appears dead (after being transported)
I have a hoover hswf167 washing machine, it's been sat in storage for about 8 months and then not plugged in in another flat for another 6 and has been transported a few times between all these places but always with the drum bracket in place. When I've come to plug it in now, it appears to be totally dead. I've tried replacing the fuse (with a known good one, and have rewired the plug as the live wire looked like it could be damaged but still nothing so must be the machine. I've taken the top off and can't see anything wrong or out of place, there is a pair of black wires with a connector not connected to anything but i don't see anything for it to connect to so I assume it's redundant on this model. nothing seems loose and i can't see any signs of blown components. But obviously i'm not an expert, it worked before it went into storage so I assume it must have gotten damaged in transport somehow. Do you have any idea what's wrong and how I could fix it? I think it's under a 5 year manfc warranty but I doubt it would cover this. It's not covered by insurance. I can take digital pictures if it's of any help. I really hope someone can help, I can't afford to call out a repair person at the moment.
  • 1,305 Answers
Washing machines have a cut-off switch that is activated by lifting the lid on the clothes compartment. Possible that the wires are to the terminals of this switch.
Take the top of the machine loose again and check to make sure this switch is connected.
This is where the power goes before it goes into the rest of the mechanism so it can appear dead.
Posted on May 08, 2009
Hoover 800el doesn't stop filling up with water. It just overflows. Recently transported if that helps?..??
it is possible that during transportation , the tub moved excessively and pulled the small hose off the tub that is connected to the water level solenoid
check around the tub for a small hose that goes to the control panel
Feb 09, 2016 | Hoover Washing Machines
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Error number 2 appears on Hoover AAA whisper 1400 washing machine - any help? When it appears which is becoming more regular that it use to be I usually end up putting the washing through a quick spin,...
I downloaded the manual from Hoover website. Error number 2 relates to the washing machine not filling up with enough water. Check the water supply and correct angle of the pipe.
Sep 15, 2009 | Washing Machines
Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Nov 18, 2008 | Hoover AAA160 Front Load Washer
I have a hoover performa 1100 and twice this year (2nd time last night, 1st time 2 months ago), it has exploded with a loud bang followed by a burning/singed smell and smoke. It is 8 years old. It has...
mains filter capacitor usually goes with a bang and puff of smoke it is usually located near to where the mains cable enters the machine fixed to the rear panel by a nut the main cable is connected directly to it then the cables from it feed power to the machine. the capacitor is usually round in shape and has four connections onto it
Jul 19, 2008 | Hoover Washing Machines
HOOVER WASHING MACHINE
I have found a solution in a UK website. Machine fixed.
Jun 09, 2008 | Hoover Washing Machines
Machine wont work
Your machine probably needs re setting hold power down for 60 seconds see if that works
Apr 15, 2008 | Fisher and Paykel Fisher & Paykel Washer
How do I replace a drum paddle in my Hoover washing machine HSWF167
there should be a plug on the top of the agitator. pry off this cap with a screwdriver. you will see the hex nut that fastens the agitator. remove the hex nut and lift the agitator from the transmission shaft. Installation is the reverse of removal.
Mar 17, 2008 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
