Question about Kohler - Toilet - One-piece - Santa Rosa - K3323-52
Kholer santa rosa only flushers half tank unless you hold down
5 Suggested Answers
Nomodo4u
  • 863 Answers
SOURCE: Leak at water supply entry into tank - Kohler Santa Rosa
Tighten the nut a quarter turn.  If that doesn't do it then shut off the water supply. Unscrew the nut and get you a new rubber washer to replace the old one.  If that doesn't do it, then go to the blue or orange box store and get you a new 12" stainless steel flex line for toilets.  Bring your old supply line in to correctly match up the size so you don't have to make 2 trips if you buy the wrong one.
Posted on Oct 26, 2009
  • 119 Answers
SOURCE: How install Kohler part no. 87988 in Santa Rosa
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
Posted on Mar 28, 2010
Geekman
  • 32281 Answers
SOURCE: Kohler santa rosa fills, shuts off, a little water leaks from tank, toilet refills and repeats the leakage into the drain.
There is a rubber seal at the bottom of the flush valve that covers the openning at the bottom of the tank. If this rubber seal has perished slightly then it will leak water into the toilet bowl. This rubber seal need to be replaced to form a proper seal to prevent water leak.
Posted on Dec 27, 2011
petercw
  • 86 Answers
SOURCE: Whine or squealing from tank when Kohler Santa Rosa toilet is flushed.
Sounds like an air lock is making the water fill in squeeze thru the piping. C if u can undo the piping from the tap below the tank and take out tank and try flushing the unit thru from the out side fill pipe. U may hv something stuck in the pipe line. cheers
Posted on Aug 26, 2012
How to replaceKohler Santa Rosa gasket
Shuit off water and remove the three bolts under the bowl in back lift off tank and remove gasket by pulling it off the bolts install new bolts inside tank install the white washers on the bolts then install them in tank and putr gasket on bottom of the tank and reinstall the tank to bowl and tighten down nuts be carefull not to over tighten bolts cause the bolts will snap the porecelain ears on the toilet.
Jun 06, 2014 | Kohler KOHGP51487 Authorized Original...
Aug 25, 2012 | Kohler Santa Rosa K-3323-55 Innocent Blush...
Dec 27, 2011 | Kohler - Toilet - One-piece - Santa Rosa -...
Water continues to overfill in tank into refill valve
Hi and thank you for using fixya:
Inside the tank there is a long standing tube that at the top end it has a little buoy that regulates how much water needs to be in the tank if you push it up you are going to see the water stops to run. So just bend it down a little about an inch
thanks
May 04, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Feb 27, 2010 | Kohler Santa Rosa K-3323-0 White Compact...
Oct 22, 2009 | Kohler - Toilet - One-piece - Santa Rosa -...
Kohler - Toilet - One-piece - Santa Rosa - K3323-52 Logo
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
