Question about Brother DCP-110C All-In-One InkJet Printer
BROTHER DCP 110C INSTRUCTIONS TO REPLACE INK ABSORPER
REPLACE INK ABSORBER
  • 133 Answers
SOURCE: Brother DCP 110C printer error
thats what I find useing the search button here:
http://www.fixya.com/support/t265668-not_printing
Posted on Feb 20, 2008
SOURCE: Printer is unable to print
EXPIRY GUIDE
Posted on Sep 05, 2008
pineworks
  • 4041 Answers
SOURCE: does anyone have the reset codes for a brother dcp
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Posted on Jan 30, 2010
  • 525 Answers
SOURCE: where do I get an ink absorber box for my brother
There is no reason to clean or replace. Just reset counter with this procedure.
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Feb 02, 2011
naresh_sh695
SOURCE: The ink absorber near full Problem with my brother
DCP j125 Inkjet printer stopped printing showing msg. ink absorber is full. What to do?
Posted on May 07, 2012
Brother DCP-110C printer not printing!
Clean the heads....................
found in printing preferences / maintainance
Jul 16, 2010 | Brother DCP-110C All-In-One InkJet Printer
DCP-110c is showing machine error 46. I have followed instructions as per cene765 solution #1 withput success. I get as far as 'maintenance 80 display. Pressed 'mono start' many times but still displays...
Many thanks - I fixed the error 46 by following the helful solution provided below.
mydcp110c
Rank: Apprentice
Rating: 86%, 8 votes
Hello!
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
Dec 11, 2009 | Brother DCP-110C All-In-One InkJet Printer
Error message : ' cannot clean print head'
Unable to clean means the ink absorber is full and needs to be replaced and the counter reset.
Sep 10, 2009 | Brother MFC-620CN All-In-One InkJet...
Print with my black cartridge ONLY
The only way is to set Grayscale Printing in the Printer Properties for DCP 110C.
I myself prints black only using this printer. Doing the above setting will minimize ( not prevent ) the usage of colour inks.
But take note that the colour ink will deplete itself matter of time.
Dec 29, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-110C Ink display is incorrect
Jake, had the same prob...this is what I did as per some advise i read online and it worked for a bit b4 i end up in another prob...disconnect the power cord for bout 30 seconds then once u restart it, remove all the ink cartridges and then replace them. after that, it should work.
Apr 15, 2008 | Brother DCP-110C All-In-One InkJet Printer
Unable to clean
you need a new waist ink absorber box and have to do a reset. The absorber box can be purgchased from a service partner (see brother homepage of your country). Same procedure:
http://www.fixya.com/support/t139675-need_reset_purge_counter_due_error_46
Mar 08, 2008 | Brother DCP-110C All-In-One InkJet Printer
you cant clean the waistinktank because when the felt dries up it wont take up any ink anymore! The rejected ink will flow into machine and cause serious demages!
Anyway you have forgotten to reset the eeprom code to tell the machine thta the ink absorberbox has been CHANGED!
Search here for error 46
Feb 15, 2008 | Brother DCP-110C All-In-One InkJet Printer
Brother DCP-110C All-In-One InkJet Printer Logo
37 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
