Question about Campbell Hausfeld Air Tools & Compressors
Cant load nails into chn 706 nailer
Loading button
  • 1388 Answers
SOURCE: D51844 Won't Fire Nails
The Dewalt D51844 uses a full round head 20 degree nail. Sometimes the generic brand nails are not made exactly to the stated degree. They do this so their nails will work on a variety of nailers. Best to check the nails angle in relation to the angle of your nailer. Place a strip of nails on the outside of the rail. Align the heads of the nails to a convenient straight edge on the rail then check that the head and shaft of the first nail is aligned with the barrel. If the lower part of the nail projects out further than the head, then the driver will miss the head. If the head of the first nail appears close enough to barrell for the driver to hit it then place a new strip of nails into the mag and slide the pusher foward. Fire one nail, if success, remove the nails from the mag and check if the plastic holding the nails together is projecting in front of the first nail. Sometimes the plastic is not right, too stiff, and will not let the next nail align with the barrell. If the next nail appears ready and slides forward then the driver may not be going all the way up after shot. Check by inserting a metal rod into barrell and push driver up till it stops. If the driver is in the uppermost position, then most likely brand of nails. Use Dewalt nail. Good Luck
Posted on Feb 25, 2009
  • 4 Answers
SOURCE: Dont know what nails to use on my makita brad nailer
is that a model AF505? if it is, your problem may be the gauge. make sure you use 18 gauge nails, he 16 gauge are too big and will jam in the gun.
Posted on Feb 26, 2009
  • 3 Answers
SOURCE: I purchased a new FN16250K-2 finish nailer today. I loaded it w/
get a senco
Posted on Mar 11, 2009
  • 65 Answers
SOURCE: Huskey finish nailer shoots twon nails at one
sounds like your nail guide has been damaged or worn try your supplier for a new guide
hope this helps ian
Posted on Mar 25, 2009
  • 100 Answers
SOURCE: how do I load nails into Bostitch SB-1664FN 16
from the side, not in the back or front.
Posted on Apr 19, 2010
How do I load my frame nailer
Just pull the pusher back along the magazine all the way until it latches. It should be located on the side of the magazine and looks like something you can grab with your fingers. Then load the nails in through the slot. Pull back on the same pusher until it unlatches and it should slide forward to push the nails toward the head.
Oct 25, 2013 | Dewalt D51844 Framing Nailer
Ism coil roofing nailer will not hold nails in striking chamber after they advance
The feeder area of the nailer incorporates small levers on both sides of the nails. On the body side, the spring loaded feeder retracts and pulls forward the first nail. On the latch side small spring loaded arm/s hold the nails in place once they are pulled forward. Open the latch and push on both the feeder and the retanier for firm spring tension. On some nailers, due to wear, the grippers on the feeder tend to wear off allowing the nail to slip out of place. On other nailers, the feeder arm/shaft tends to wear and alows the feeder to move out of alignment (check if the actual feeder arm can move from side to side). The feeder shaft should move forward and back with no side to side movement. Finally, some coil nails are welded together with too stiff of wire. After the first nail is driven, the second nail will have one or two strands of wire pointing out not allowing the nails to move into position. After first shot, the two wires should be cut off or bent down out of the way. Good luck.
Nov 02, 2012 | Air Tools & Compressors
My brand new DC608 18 gauge nailer jams every time on the 2nd nail.
Per your addendum I would have first told you to check that you are using the proper guage nails. Second you should make sure you are loading the nails in the lowest channel in the magazine so they are at the bottom of the magazine. If you load them into the top of the magazine they have more time to go off course before they get into the wood.
May 29, 2012 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
How to load bostitch sb1664fn nail gun
Push on the button on the rear of the tool to open the magazine. Pull the magazine back. Load nails in the stationary part of the magazine with the heads of the nails at the top of the magazine. Push the sliding section of the magazine back into place making sure it latches.
Jul 04, 2011 | Stanley Bostitch FN16250K - 2 16 - Gauge...
How do i load nails in my porter cable clipped head framing nailer...
Pull lever back on top of clip, slip sleeve of nails into slot, then release lever to push nails forward as you use nails.Make sure you are you the right gage of nail.
Jun 18, 2011 | Porter Cable FactoryReconditioned DA250BR...
How do i load the fastners into the f21pl?
Pull the nail tension slider towarrd the back of the nailer. It should click into place. Load the nails throught the slot on the top of the long flat magazine. Press the tabs on the slider together to release it and it will provide the tension on the nails.
Dan
May 30, 2010 | Stanley Bostitch F21PL Nailer
Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Apr 05, 2010 | Stanley Staple/Nail Gun Elec
How to load nails in the paslode f350s framer purchased a used nailer now trying to figure out how to load the nails
Hi, I found you a free owners manual for your model. Click on the link below and save or print.
http://www.paslode.com/uploadedFiles/pneumatic_ops_manual.pd f
Hope this Helps, RSMITH972278 P.S. PLEASE RATE MY ASSISTANCE
Dec 29, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Piston that advances coil of nails doesent reload nail coil.
you need to load first nail in coil into trap so it pulls the rest through..
Oct 27, 2009 | Senco SCN 65 XP Coil Nailer Toe Nailer
I have bought a tacwise 140EL nailer/stapler. I
Turn the gun upside down and pull out the black plastic loading thingy, drop the nails in the left hand side of the gun,press against side with finger and slide black loading bit back over top of nails-hey presto!
Oct 13, 2009 | Tools & Hardware - Others
Air Tools & Compressors Logo
66 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
