Question about Sanyo DVW-6100 DVD Player/VCR
I don't know where to put the yellow, red and white connectors on the TV or the dvw
How do i hook up mysanyo dvw 6100 dvd player vcr combo to my new flat screen tv
  • 975 Answers
Look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
Posted on May 08, 2009
How to hookup Sanyo DVW-6100 to a Sylvania tv
If the Sylvania tv is a CRT (old style tube tv) you can just use an RCA cable and hook it into the composite video. It will be the cable that has a red, white and yellow connectors on it. The yellow is the video, the red is the right audio and the white is the left audio. Connect ones side of this cable to the output of the DVD/TAPE player and to the input on the TV side.
Sep 04, 2014 | Sanyo DVW-6100 DVD Player/VCR
How do you record a t.v. show using the VCR on a Sanyo DVW-6100 combo?
Use a "1-to-2" splitter on the cable between the output from the Direct TV box and your TV. Connect 1 of the 2 to your TV.
Connect the other cable to your VCR.
Apr 26, 2014 | Sanyo DVW-6100 DVD Player/VCR
I have an old sanyo vwm 710 vcr. I have a new hdtv. I can play tapes on the tv if I change the input on the tv. I have selected line 1 on the vcr, but cannot get any channels to come on to record. The...
Not really a solution....RCA customer services (from India, I think), says that there is no way with that VCR because both the front and back (red, yellow,white) ports are input, and the only other jack on the tv is the one for the antenna. Since the digital converter is inside the tv, a splitter would do no good.
I would still have to get either a new VCR with the digital converter in it or get another converter box. An atmosphere of bait and switch is covering this hdtv scheme....
Feb 19, 2009 | Sanyo DVW-6100 DVD Player/VCR
Question
Yes those players sell for around $399 depending on the source. You can google your brand and model # and put prices at the end and it will search for different sources and different prices.
Jan 26, 2009 | Sanyo DVW-6100 DVD Player/VCR
TRYING TO HOOK UP OLD RCA COMBO (DVD/VCR) TO MY NEW TV. USING THE RED/WHITE/YELLOW CABLES ALONG WITH PUTTING MY CABLE SIGNAL DIRECT INTO THE DVD/VCR PLAYER AND THEN CONNECTING THE OUT LINE TO THE NEW...
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Oct 16, 2008 | RCA Televison & Video
Hooking up a d.v.d player to a vcr/tv combo?
RCA plugs (the yellow, red, and white outlets you speak of) consist of a video plug (yellow) and stereo plugs for audio (red and white). Just match the colors from the DVD RCA colors to the RCA hook-ups on the TV (ex. Yellow the Yellow, White to White).
You don't need to worry about the red one, it just makes the DVD player play stereo audio. Instead, you'll have mono, which is fine, and most modern players can detect mono and switch it for you so don't worry about changing settings and what not (unless you're missing sound on one side.)
Sep 13, 2008 | Optical Coating Model 108 VHS VCR
Sanyo dvw-1600
The motor for the DVD drive may be busted. I reccomend getting a new DVD/VCR Combo. otherwise, your dvd player is basically fried
Sep 03, 2008 | Sanyo DVW-6100 DVD Player/VCR
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
How to hook up my dvd/vhs combo to my tv with out the red,yellow and white cables
go to radio shack and get the red and white and yellow cords.
Dec 23, 2007 | Televison & Video
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
Sanyo DVW-6100 DVD Player/VCR Logo
359 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
