Question about Proform C950 Treadmill Walking Belt
Proform C950 intermittently stops working shortly after start
Most occasions that I try to use my Proform C950 it stops within the first minute. The display remains active, but the belt stops moving and won't start again until I hit Stop or pull and re-insert the key. I bought the treadmill used and it worked well for the first several months. Then it would occasionally stop when I was at a full run and gradually got worse to the point that it stops almost immediately after starting a slow walk. It does seem run well with no one on it. I have seen several online sources indicating that I should use a silicone spray on the belt, but the manual specifically states that I should not do that.
    Top Expert:
  • Proform Master
  • 12,223 Answers
Please see the video attached. lube the rollers bearing front+ back
2) test the input terminal voltage motor, if there ARE the motor is faulty. see my personal TIPS for motor help 3) test the output voltage board, if there ARE NOT voltage for input voltage MOTOR, the board is faulty.
God bless you
Proform C950 intermittently stops working shortly  - 023b151d-214b-4836-97ca-4292e7bb8287.jpg
Posted on Nov 28, 2013
Testimonial: "Thanks for your answer. The video that you posted is for lubing the belt, not the roller bearings as you suggested. I have new information. The treadmill will now stop shortly after start even with no one on the belt. I took off the cover to observe the troubleshooting LEDs on the control boards. The motor control board 15V LED is lit indicating it is receiving power. The SPD SIG LED blinks rapidly, when I command the treadmill to start from the console, indicating the signal is received. The GATE LED lights up proportionally to treadmill speed, but then goes dark when the treadmill stops."
SOURCE: The belt on my ProForm Crosstrainer treadmill stops while using i
Sometimes the tread needs to be lubricated. This was the case with ours. You can get a lubrication kit at ****'s Sporting Goods or other larger sport stores and it will instruct you on how to do it.
Posted on Jan 26, 2010
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
  • 40 Answers
SOURCE: My Proform 650v treadmill stop when running after couple of miles
Most likely a bad drive belt. Take the cover off the motor area. If you see black dust near the left side of the motor, replace the drive belt.
Posted on Nov 01, 2009
valeantudor
  • 787 Answers
SOURCE: I have a model 297980
You have to put the safety key in if you want to select speed/incline or predefined programs.
It starts and runs at full speed on that occasion because it's part of the maintenance process, that lubricates the inner rollers so that it will continue to work perfectly for as long as possible.
Posted on May 01, 2010
maxtreadmill
  • 832 Answers
SOURCE: my treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
Posted on May 16, 2010
Pro form 320x treadmill stops working when you get on it
How can I get my Proform 320X treadmill from stopping a ...
www.shopyourway.com > Manage My Life > Questions
How can I get my Proform 320X treadmill from stopping a few seconds after starting? ... -why-does-my-proform-treadmill-belt-only-move-a-few-seconds-stops
ProForm Treadmill 320x User's Guide ' ManualsOnline.com
fitness.manualsonline.com > ... > ProForm Treadmill
ProForm 320x Treadmill User Manual. Page 1. Page 2. Page 3. Page 4. Page 5. Page 6. Page 7. Page 8. Page 9. Page 10. Page 11. Page 12. Page 13.
Nov 03, 2015 | Exercise & Fitness
We have a proform crosswalk advanced 525 and everytime I get on it will shut off within 3 to 5 minutes of starting. The power will not go off. Only the belt stops and I will have to restart the treadmill...
Most likely your problem can be with the motor control board, with the kids, the motor is not pull many amps, so the treadmill will operate normally. Replace the Motor control board
Feb 28, 2015 | Proform Exercise & Fitness
ProForm cross trainer 565. Press start it races for a few seconds then stops. The console keeps going as if everything is still working.
One of the motor controller transistors is shorted.
Phone ICON customer service and order a new controller. It is relatively easy to install. The phone number is on the model number tag..
Feb 05, 2013 | Proform 565 Crosstrainer Treadmill Console
I have a model 297980 J8 proform treadmill. when I first start it up without the safety key in it, the treadmill runs at full speed for about 2 minuets. After that it slows down and stops. The speed is set...
May 01, 2010 | Proform Exercise & Fitness
Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Mar 09, 2010 | Proform 7.0 Crosstrainer Treadmill
1993 Honda civic speedometer & odometer work intermittently
the only thing that is related is the d4/rough gear changing
speed/ rpm malfunction is caused by your speed sensor on the trani (common problem) change it
Sep 20, 2009 | 1993 Honda Civic 4 Door
Treadmill stops running
I had simillar problem. I have proform 830 QT. My trademill stops after 10 minutes of work out. Everything shuts down and the circuit breaker pops out.
Root cause:- no lubrication under walking belt. Caused the moter to over work (over heat) and hence te circuit breaker popped out to prevent blowing of motor.
Solution:- Apply the lubricant under walking belt and adjust the belt tension if needed.
Back ground:- Contact proform customer service at 1-888-533-1333 (http://www.iconservice.com/proform/faq_tread.html) and buy the treadmil cleaning kit or lubricant kit which comes with a wand for easy application. It may cost you 35 dollars including shipping. If you need to fix your treadmil right away, use NAPA silicon spray 8300. Proform actually tells do not use it as it may damage your belt. However the specialst who came to fix my treadmill just sprayed it and collected 100 dollars. When I called proform they told me lubricating will fix it and its my mistake to not trust them. I guess they knew exactly what they were saying.
Dec 03, 2008 | Exercise & Fitness
Electrical or computer problem; intermittent
You might have a problem with the body contro module, have it tested for codes.
Nov 21, 2008 | 2003 GMC Sierra
Proform C950 Treadmill Walking Belt Logo
406 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
