Question about Microwave Ovens
I need an oven manual for Western-Holly 1950's wall oven
Trying to fix my Western-Holly wall oven
GE Range
Look at this example for common places where GE puts their model number so that you'll need to waste energy trying to look for it.
Sep 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How do i obtain an owner's manual for a GE 326b1230p001 wall oven installed in 1999?
search on google.com for one but 15 years I would suspect more problems sooner than later
Feb 28, 2015 | GE Microwave Ovens
Schematics for kitchenaid model kemc307
see the information attached for fix it. Merry Christmas
Dec 16, 2013 | KitchenAid Microwave Ovens
Trying to change a fuse on microwave.
It may be the fuse or the thermal cutout / thermostat associated with the magnetron.
You say you have the service manual? If you mean the folded-up "mini-manual" that should show the relative locations of the parts in a perspective view.
Also, you can find exploded views at the Sears parts site.
Looking at the "interior parts ii" exploded view here, it shows the fuse (drawing reference # 5001) on the small RF noise filter board located on top of the air duct assembly.
You'll need to remove the oven from the wall to get to it for testing & replacement.
The installation instructions are handy to pull the oven from the wall.
If you've misplaced yours, the Sears site may have them free.
You can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they may ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
May 28, 2010 | Kenmore 80809 Microwave Oven
We're trying to remove our sharp R-1420B microwave oven off the wall. We're having absolutely no luck. How do we get this off the wall?
I just removed our Sharp R-1420B microwave. Unplug the microwave. Start by removing the two bolts from the top cabinet (one left and one right). Remove the decorative screws (one left and one right) from the bottom support bracket. I used a plastic bucket sitting on the range as support under the microwave (you may need a couple different sizes). Once the bucket is in place, pull down on the attachment brackets where the decorative bolts were located near the bottom. I used a vise grip to attach and pull them down, and they came down fairly easy. By doing this, the top of the microwave should become detached from the wall. Once you allow the microwave to tilt down far enough (you may need to move the bucket or use a shorter one), you should be able to lift the bottom of the unit off the lower support bracket. Now you can just pull it out from the wall.
May 16, 2010 | Microwave Ovens
TRYING TO TAKE MICRO OFF THE WALL AND IT WON'T BUDGE. NEED INSTALLATION INSTRUCTIONS
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
May 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need to install oven to wall
You can download GE owner's manuals and installation instructions here.
Dec 28, 2008 | GE JVM1651 Microwave Oven
I have a double roper oven Model #39758B0 Serial # 8Roo896 Problem when turning the top oven on I get an F-5 signal and the oven does not turn on. I need to know how ro fix this problem. Thank you, Rita...
My problem is with a roper double wall oven not a micowave. When turning the top oven on I receive a F-5 signal and the oven does not turn on. I misplaced my manual hoping you can solve this problem or send me the manual.
Thank you,
Rita
Sep 16, 2008 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
131 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
