Question about Peavey Audio Players & Recorders
Casio pv 250x - Peavey Audio Players & Recorders
I would like to buy a replacement stylus for my Casio PV-S400 Plus. Where can I do that?
Hello. you can purchase a stylus at Radio Shack, or Walmart, or Staples. Regards, Joe
PS please rate my answer. Thank you.
Dec 20, 2009 | Casio Pocket Viewer PV-S400 Plus Handheld
Problem in connecting Casio PV-S660 with PC
Dear Sir, I purchased Casio Pocket viewer PV-S660. My lap top is having Window XP professional and I am unable toconnect . kindly suggest. K.A. SUBRAMANIAM
Feb 02, 2009 | Casio Pocket Viewer PV-S660
Drivers for CASIO PV-S400 Plus
I think i can help you please e mail me if you are still interesing
doraalbaos@prodigy.net.mx
Oct 15, 2008 | Casio Pocket Viewer PV-S400 Plus Handheld
Casion PV-200
Hi I was given a Casio PV-200 2MB. I connected to the computer to start it up and even though I have changed the batteries 4 times it won't switch on. Do I need soft ware? The thing won't even charge. Could you please help me?
Thanks
Sep 02, 2008 | Casio Pocket Viewer PV-200
Need installation cd or download for Casio PV s400plus
driverguide.com it is all there, else email me s*e*a*n*&g*4*t.co.za
Mar 29, 2008 | Casio Pocket Viewer PV-S400 Plus Handheld
Not able to synchronise
did u set the pc-sync up to use the correct com port? got menu, then, casio, then, transmission setup and configure correct serial port.
Feb 04, 2008 | Casio Pocket Viewer PV-S400 Plus Handheld
Casio Pocket Viewer PV-S400Plus not working
When batteries are to be replace you must move the switch on the back cover to "replace batteries". After you replace the batteries, you must move the switch back to "normal operation". The unit will then want you to touch the dots in the cross hairs and then ask you to adjust contrast. Try replacing the batteries again with a fresh pair. If this does not work, open the cover with the switch in the "replace batteries" position and use your stylus to press the "P" button underneath the battery cover and try again. If this fails, try resetting the unit.
Jul 25, 2007 | Casio Pocket Viewer PV-S400 Plus Handheld
35 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Jaime Hernandez
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
