Question about Home
Maxx air tub jets clogged
Only some blow air. Some don't. How can I fix this?
3 Suggested Answers
brainyass
  • 242 Answers
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
Posted on Oct 24, 2008
uspartscente
  • 717 Answers
SOURCE: Maxx jetted tub quit pumping water, pump motor just races.
When the bath pump runs and you get no water going through the jets in your bath Jet trim then the impeller has probably spun off the shaft of the motor.You will not know if this is the case until you take the bath pump out and remove the front cover of the bath pump and check the impeller.If this is the case it usually has to be replaced.
Rod
US Parts Center
888-521-6183
Posted on Feb 28, 2013
How do I fix a jet that isn't hardly pumping on my Aqualux jet tub? The other 8 jets work but no more bubbles. Is it the switch? Is that one jet clogged? Do I need a new pump? How do I get the jet out
hello Tami!
That particular jet is probably clogged.
You can find special cleaners NON ABRASIVE at your local hardware stores.
Be sure to tell them what cleaners you are looking for to make sure it is a non-abrasive type.
Or call in for service. Here is a link that may be helpful to you.
Best of Luck,
JP
Bacteria Alert How To Easily Clean Jacuzzi Bathtub Or Whirlpool Tub Hot...
Oct 28, 2015 | Home
The jets on my aker Swirlbath are coming on by themselves in the middle of the night. What is the remedy for this problem?
Some tubs with air jets have a sensor that detects water in the piping and cycles the air pump to blow out the water in the air jets. Make sure the faucet is not dripping as the water leaking into the tub could be causing the pump cycling problem.
Hope this helps.
Bob
Aug 11, 2014 | Home
I have a Neptune air tub and the motor turns on when I press on but the air is not coming out of the jets. The tub does not have an air knob
So you can hear the air blower turn on however there are no little bubbles coming out of the air injectors...
I would have you verify that the blower is blowing air out. Either the hose has come off and it is blowing air under the tub or the fan has disengaged itself from the motor and is not turning.
I will ask you to verify that one of those two things has happened or possibly the check valve in your system is closed and will not open.
US Parts Center
Nov 10, 2013 | Neptune DB60TAM Whirlpools and Air Tubs
Wiper fluid comes out sparingly and not all the time, motor works
Be sure you have 12 volts at the pump motor, and that the pump intake is not obstructed. Then, make sure the jets are not blocked on the hose side, as the jet diameter is smaller than hose diameter. I would remove the hoses at the jets and the pump and blow air backwards through the system. Also, blow air backwards through the jets to insure they are not clogged inside. Replace all hoses and try system, if no change, then the pump itself is bad, probably a bad impeller in the pump. This should fix the problem...Good luck.
Jan 24, 2013 | 2004 Acura TL
Our "whirlpool" tub jets do
sounds like it may be either the air button or the air switch (on motor).
pull the pump and plug into an outlet. take a straw and blow into the air switch where the air tubing was connected. If the pump comes on then you know the button. If the pump doesn't come on then you will need to replace the air switch on the back of the motor.
Feb 07, 2011 | Home
I have a brand new walk-in tub with whirlpool and air jet. It has air switches for both features. My problem is that the air pump comes on all by itself after sitting for 20-30 minutes of non use. It does...
This is known as the purge cycle, it is very normal. It is to blow out any remaining water from the air jets. If it was to allow water to stand in the pipes, it would start to smell and grow algae, which would then clog the small air holes, nothing to be alarmed about.
Mar 12, 2010 | Whirlpool 5"x36" White Bathroom Drop-in ...
Water runs very slowly when trying to fill jet tub.
Check to see if there are any screen type filter to the tub as debris may be clogging it. Also air lock can occur but it should not be causing problems as 90% clear them selves.....
Feb 15, 2010 | American Standard AMERICAN STD Savona...
2004 MALIBU MAXX A/C BLOWS HOT AIR
Could be several things. The fuse relay to the AC compressor could be bad. The system may need to be recharged due to lack of refrigerant the compressor will not work unless it has enough.
Jul 19, 2009 | 2000 Dodge Neon
Sep 28, 2008 | Home
Home Logo
41 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
