Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Have sony model KP 53 HS 10 picture flashes of and on intermeitantly and red light flashes 5 times I know this is some type of diagnostic code but have know idea what it is. Help
SOURCE: troubleshoot-5 blinks red light front of TV
Hi, I have a similar problem with my KV25x5 it seems to be the CRT. I have just brought a new TV rather then fix it. Try http://www.iwaynet.net/~nesda/SonyBlink.html as a starting point & google "sony 5 blinks" Jesh
Posted on Jun 02, 2007
SOURCE: sony tv red flashes
LED flashes of 8 times are indicative of a "High Voltage Error" which means something along the lines of "T8005 is faulty. (D board)" according to the service manual. Most likely it will need a professional to look at it. A link to the service manual is here: http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on Jul 02, 2007
ginko
  • 19396 Answers
SOURCE: Sony KP-51WS520 Stand by flashes 5 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
This means that there is something wrong with the video.
When you get this error, several IC and components concerning the video signal must be tested and eventually replaced.
Posted on Dec 01, 2008
  • 15 Answers
TURN TIMER OFF. GO TO SONY.COM, TROUBLESHOOTING, OR The STANDBY light is flashing on the television and there is no picture or sound. Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Posted on Jan 16, 2009
romsky79
  • 822 Answers
SOURCE: 10 BlINKING LIGHTS ON SONY TELEVISION
in these sets you have to check the power supply board. check all capacitors maybe blown on top.
Posted on Jun 07, 2009
The red light is blinking 3 times and i have no sound or picture
I do not think this model has a 3 blink code, I could be wrong but is it possible the model indicated is not the correct model number?
Dec 20, 2012 | Sony KP-53V80 53" Rear Projection...
HI...WE HAVE A SONY PROJECTION TV, MODEL #KP 53 S 35, NO PICTURE NO SOUND, DARK SCREEN, JUST SMALL FLASHING RED LIGHT ON CONTROL PANEL (STANDBY LIGHT). NO POWER ON SOUND WHEN TURNED ON. TOLD WE NEED...
http://www.moduslinkptstvboards.com/search.php?search_query=A+1316+295+A&x=7&y=13
try this....may have to send board to them for repair.....good success, meder's tv service
Sep 22, 2011 | Sony KP-53S35 53" Rear Projection...
I have a Sony KP-53V90 53 with no display and red light flashing
This is a good one. Your TV "looks" at the feedback coming from each picture tube in your TV. When it doesn't see what it expects, it kicks out a 5 flash. Most commonly, the correct signals never got to the picture tube(s) and that's why the feedback was abnormal. Which brings us to the most common solution: C boards, they attach directly to the bottom of the picture tubes. Figuring out which one has a problem... that's another matter. Due to the age of the TV, parts costs are rising. Each C board (3 in the TV) runs about $100 so guess work can be expensive. I hope this was helpful.
Mar 28, 2010 | Sony KP-53V90 53" Rear Projection...
KP-57WS520 Sony Projector - No picture
5 times blinks shows incorrect white balance (AKB) error. TV needs Screen Volts (G2) adjustment.
Take off lower front panel, find Focus Block that has 6 control knobs, adjust Screen volts of each CRT (red-green-blue) and problem will be solved.
Be Careful while working in TV.
Let me know if you have further question.
Thanks.
Dec 09, 2009 | Sony KP-57WS520 57" Rear Projection...
65" projection tv will turn on and shut off before picture comes
the service light is blinking because you in fact need a new bulb also is why u have no picture
Oct 06, 2009 | Sony KP-53V75 53" Rear Projection...
MY problem with Sony KP-53S35 53 in. Rear Projection Television. When the TV powers on, the red light blinks until the picture comes on, then the red light blinks go off. I had to wait more than 5 minutes...
the number of flashes of the red indicator lamp points to the possible cause of the delay of the raster or picture, but usually it's an indicator of an emission unbalance between crt(picture tube) guns. the picture will take longer to show up as the emission on either of the picture tubes goes down.
Jul 27, 2009 | Sony KP-53S35 53" Rear Projection...
Red screen on my sony kp-53s25,
That model is famous for bad green CRTs which can cause the screen to take on a red hue when the green cuts out that can also cause the set to get blurry also. Let me know if you need more assistance.
Jun 12, 2008 | Sony KP-53S65 53" Rear Projection...
Sony kp-65xbr10w led light blinks 5 times
i have a sony tv model kv36fs17. led flashes 5 times. tv works but no red color. would could be the problem? thanks
Jan 23, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
105 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
