Question about Electrolux AEQ8700F Electric Dryer
E60 and beeping
Stops working through cycle and starts beeping error E60 shows up
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Alannah, thank you for allowing me to assist you!
Typically error code E60 could potentially mean the heater relay has short circuited or there is a wiring malfunction. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Posted on Dec 03, 2013
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Feb 21, 2015 | Electrolux Washing Machines
Why is my dryer beeping and showing E60?
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed): - Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
  • Heater unit faulty
  • Wiring faulty
  • NTC sensor incorrectly calibrated/out of position
  • Electronic board faulty
E62 - Power reley to heater unit faulty
  • Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
  • Thermostat faulty (replace heater unit)
  • Wiring faulty
Dado
May 10, 2014 | AEG T57800 Electric Dryer
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Model Gw709AU
Feb 20, 2013 | Fisher and Paykel Washing Machines
My AEG Lavamat 66600 Washing Machine is showing E60 Message how can I remove it to get the machine working again. Thank you
Please remove the power plug and depress all the buttons on the panel, while the power plug is inserted and power switched on , press on the start/pause/stop. it must restart the controller unit or there can be external or internal errors as designated by E60.
Check the door switch,drain pump and inlet flow.
Jul 25, 2012 | AEG Washing Machines
Hi I have an Electrolux dryer which has started showing the error message e60, when i hold the start button and the one next to ity I get error e62 showing can you help?
the "E60" error code will appear when there is an error with the door switch and sensor, An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
the "E62" error code will appear when the lint filter and tubing need to be cleaned or replaced. The dryer will start and run for 15 seconds before shutting off. It will restart when prompted and run for another 15-20 seconds before shutting off. These steps must be repeated until the dryer continues to run the full cycle. Tim
May 12, 2011 | Dryers
What is the meaning and fix for error code E60 on a John Lewis JLDV08 tumble dryer. The dryer stops mid-cycle, the door pops open, and code E60 appears on the display.
When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
May 08, 2011 | Dryers
Just hada brief power flash. Washing machinbe was on. Now just keeps beeping with E60 lfashing on the screen. Not continuing cycle. Can't open door. Can;t re set
The E60 is not listed but it means the cycle was interrupted due to a fault with the motor.
You don't provide many details about what is happening or when the code is displayed.
Try to run a drain and spin cycle and see if the motor will turn.
The E60 error most likely means there is a problem with the motor.
Mar 13, 2011 | Washing Machines
After washing heavy load mashine spin cycle not working
Hi just read your posting.Does your machine drain the water .When your machine stopped doing the spin cycle did it start to beep and show a series of lights as an error code?Or have you got the model with the LCD display and it showed an error code in letters?If you have the model with lights and your machine beeped the lights that did come on will be in a row of 8.Starting from left to right is it the 2nd and 5th lights on or the 4th and 8th lights---etc---- that are lit? Please reply and I can help you rectify this fault for you.
Jun 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel mw511 pride
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
Jun 13, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Electrolux AEQ8700F Electric Dryer Logo
722 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
