Question about Whirlpool Washing Machines
Whirlpool AWM 123
The light comes on but it is not filling and drum is not turning
    Genius:
  • 1,198 Answers
See if anyone else on Google is having the same problem........
Posted on Nov 28, 2013
4 Suggested Answers
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
yalmer
  • 552 Answers
SOURCE: whirlpool awm 049 washing machine
If the washer leaks only during the fill cycle, check the following:
Air-gap device: The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube:There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout:Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During spin cycle only:
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Look at the entire hose and correct any problem you find. Also, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it.
Pump: If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Main tub seal: The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Outer tub:The steel or plastic outer tubs can rust, split, develope a hole in some way. If this happens, you may have to replace the outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Feb 07, 2008
Coldcut
  • 1554 Answers
SOURCE: Whirlpool AWM 8103/1 error FP
it looks like you have a clog filter or pump issue.
take a look at this forum
http://www.howtomendit.com/answers.php?id=53072
Posted on Feb 25, 2008
Whirlpool awm323 drum not going round
JT where do you get these Ideas! OK, who have you been talking too!? I'm Jealous. LOL. Someone has been feeding you a load of CR#P! OK? The "brushes" are Inside the motor which would be Completely replaced (the Motor). You called some idiot and he told you that? What a Dork! That is like me telling you need New Fillings for your teeth cause they are crooked! If your machine doesn't spin and it is older than 7 yrs or close. Get a New One. Other than that get someone from Sears to come out and look at what is Exactly going on!
Jan 16, 2014 | Whirlpool Washing Machines
AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
May 06, 2010 | Whirlpool AWM5104/1 Front Load Washer
Whirlpool awm 312 goes through cycle but drum does not turn belt is ok
hi
a user manual for awm 312?
i didn't find on net.
thanks
Mar 14, 2010 | Whirlpool Washing Machines
Whirlpool AWM 045-1000 washing machine has suddenly stopped working and warning light "WATER STOP" has come on. Any ideas for a fix?
Sep 19, 2009 | Whirlpool Washing Machines
Leaking water from a whirlpool AWM - 293 front loader
I too have this model machine. The leak in my case traced to the fill up hose that attaches to the drum. The seal at this point seems to be a weak point and requires either a replacement that will only last another couple of years or you could try what I did.
I removed the rubber hose from the drum. Dried and cleaned it thoroughly. placed a fair bit of sealant (silcone) on both parts and reassembled and let sit for a couple of days till it cured. This will need to be redone in about 3 years (that is my average- have owned it for 10years).
Jul 26, 2009 | Whirlpool Washing Machines
Whirlpool AWM 8900 wont fill with water. Solenoid is ok but there is no power output to it from the control box. I fitted another control box from a known good machine but it still didn't fill. Eventually...
perhaps the small rubber tube that comes from the drum to the pressure switch is blocked with soapy gunge ...what i do is PULL OUT PLUG to CUT OFF POWER .dis connect tube off pressure sensor and use ballon pump to clear tube. reconnect
tube to sensor and test machine.
Apr 30, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
