Question about Arctic Air 22 cu. ft. Commercial Freezer F22CWF
Just the light is on
Came back from vacation and all that was on was the light. unplugged and plugged and same thing. I'm assuming that its not the fuse due to the light working. is there any other things I should check?
    Genius:
  • 1,198 Answers
Start at the defrost timer. Most have a manual advance knob. If the unit comes on, the timer has worn out.
Posted on Nov 28, 2013
  • Kimberly Palm
    Kimberly Palm Nov 28, 2013
    tried that and not luck... Nothing :(
  • mike kirschbaum
    mike kirschbaum Nov 28, 2013
    My favorite diagnostic tool is a non-contact voltage detector. I call it my 'tweety bird', cause that's the sound it makes. Anyway, track the power from the plug to the thermostat, to the compressor. Whever the power goes in but not out is the problem.
Deplay light and inside light off,door ajar and compressor running
I appreciate your inquiry, stephen couch!
From the information you have provided the lights on and inside of your freezer are off and your compressor is running. This sounds like a possible short within your control panel or wiring issue. I see you have performed a reset on your freezer by unplugging it and plugging it back in. Typically, to perform a factory reset we would suggest unplugging your freezer for roughly ten minutes. If that does not help I would suggest having a professional come out and perform an accurate diagnosis. This will help avoid any unnecessary part purchases. Best of luck! -Matt
Jan 31, 2015 | Frigidaire Freezers
We have a Kenmore Elite Freezer Model #253.29082994. We had the freezer plugged in and it was working fine. We unplugged it and moved it and now when we plug it in it won't start. Is there some kind of...
You refrigerator was made by Frigidaire Adaptive Defrost Controls Frigidaire Refrigerator Trouble Shooting and Diagnosing
On the initial plugin, or when power is restored to the fridge after a power outage:
If terminating thermostat is open, the fridge enters a compressor (cooling) cycle.
If the terminating thermostat is closed, the first defrost cycle occurs 1 hour
after initial plug-in.
Maximum defrost cycle time is 24 minutes.
Minimum time between defrost cycles is 6 hours. (compressor runtime)
Maximum normal clock time between defrost cycles is 12 hours.
Maximum time between defrost cycles (in "vacation" mode) is 72 hours.
Vacation mode is not entered unless the door has not been opened in at least 24 hours.
Note that the ADC will only enter the defrost mode if the terminating thermostat is closed. If the terminating thermostat is open when defrost is initiated, the ADC board will wait for six minutes and then return to the cooling mode.
ASSUMING that the fridge has been on and running,
and the terminating thermostat is closed,
defrost is initiated by pressing the door (light) switch
at least five times within six seconds.
The defrost heater should start heating up within 8 seconds.
If the above procedure caused the heater to heat up, the ADC board is probably bad; replace it.
If the defrost heater does not heat up, test the defrost heater, terminating thermostat and cold control for continuity as follows:
Unplug the fridge from the wall. Unplug the ADC board from its connector.
Test the connector for continuity between the following leads:
Defrost Heater = DEF TERM (blue) to DEF OUT (brown).
Terminating Thermostat = DEF TERM (blue) to NEUTRAL (lt blue).
Cold Control = COLD CONTROL (orange) to L1 (black).
Replace the defective component.
dvfxnxxsllnll3xsyszyldhiovfnqznnvujbtluyw2q4uxl2ntjkcdj6njhpmxnefkntwws4bi9kdg83ay5nd0jdsnhpljetrth0supsduvxugpczlkyaszhzu1onu9xwdfjv0xta0jidtfiwg%3d%3d
Apr 26, 2011 | Kenmore Freezers
My Kenmore Upright Freezer Model 25326432100 flashed "ER."
My freezer was purchased in February, 2004. It is a self defrosting freezer but ice has started forming along the bottom shelf and back wall. Also, after cleaning the freezer the other day it has stopped clycing. The freezer will stop running only if I turn it down to the #1 setting and then it will not come back on. If I turn it up to a higher setting the compressor will not stop running. It ran for over 24 hours and would not cycle unless I turned it off or set it at the #1 setting. When I unplugged it and pulled it away from the wall, there was a green water spot the size of a dinner plate underneath the freezer. Help!! Very Unhappy this freezer is only 6 years old. S in Phila.
May 31, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer says "of" on display
I assume that stands for off... there are 2 parts that affect compressor operation...
t'stat
timer
t'sat could keep the compressor from running if it is bad. to check unplug freezer. . get to t'sat and take the 2 wires off it. then jump them together.. plug back in if the compressor kicks on he replace t'sat if it dont replace timer (timer maybe stuck in defrost)
jope this was helpful
Mar 06, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Upright Deep Freeze Stopped Working
the compressor relay is gone For a few dollors you can still save it.
Mar 27, 2017 | Kenmore Freezers
Kenmore 14CF upright freezer will die after a day or so
The defrost timer is faulty or you have a defrost circuit short, unplug remove back panel inside the freezer and check for a short in the heater and defrost thermostat.
Dec 30, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer Not Working
The most likely answer is a slow freon leak assuming it was getting to the right temperature before you went on vacation.
Jul 16, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Fridge freezer lights flashing
the flashing red light indicates a cooling problem,you should call honest local appliance repair shop(not sears they rob you blind)one other thing to try is to unplug for 5 minutes then plug back in and see if it reset sets itself,could be just a board reset issue,let me know-mike
Jun 10, 2008 | Freezers
Arctic Air 22 cu. ft. Commercial Freezer F22CWF Logo
60 people viewed this question
Top Arctic Air Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
AJMAL KHAN
Are you an Arctic Air Freezer Expert? Answer questions, earn points and help others
