Question about Toshiba Satellite P25 Notebook
Toshiba p25... this unit will not power up. when the power plug is plugged in, the front power led will flash once and then nothing. the unit will not power up with or without the battery installed.
  • phat_pat1964 May 09, 2009
    meter reads 19.2 vdc and power supply rates 19v 6.3a.... wiggling the plug at the computer has no effect. when plugged in the led for main supply flashes on green and then goes right off. when the led flashes on i hear a very faint click from inside the computer.
  • Nelson Olaso
    Nelson Olaso May 11, 2010
    hello...would like to know more about?..just send on my email..
    Champion:
  • 381 Answers
Hello...if you have extra ATX power supply can you try to replace then try to boot the unit if not working u need to try and remove board inside the casing and try to test only,Mother Board,Memory,Video Card And Power Supply of curse..thanks...^_^
Posted on May 09, 2009
  • Toshiba Master
  • 32,281 Answers
When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
The adapter is faulty or the connector is not making proper electrical contact this LED will not illuminate. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Check the adapter with a multi-meter, the voltage reading should be a slightly higher than the voltage that is printed on the label on the adapter. If the voltage is more than 10% below the nominated voltage then replace the adapter it is faulty.
Posted on May 08, 2009
  • Chris Hingee
    Chris Hingee May 09, 2009
    Since the power adapter and connector is eliminated, the problem may be the RAM.
    The RAM module/s may only need reseating to make proper electrical connection.
    If this still doesn't work the the RAM module/s is possibly faulty. Take it to your friendly computer shop the get it tested or insert it into another laptop to test the RAM.
No picture and red light flashes about five times, pauses, then starts flashing again
Disconnect
CN SC20 on the SC board. Turn on the unit. Does the power LED
stay on?
Yes
SC
Board
No
Connect
CN SC20. Disconnect
CN SS23 (*1) on the SS board. Turn on the unit. Does the power LED
Stay on?
Yes
SS
Board
No
Connect SS23 (*1).
Disconnect CN D31and D32
on the D board. Is pin 5of CN P25 shorted
to GND?
Yes
Disconnect
CN P25. Is pin 5 of the socket P25 shorted
to GND?
Yes
P
Board
No
D
Board
Connect D31
and leave D32 disconnected.
Is pin 5 of CN P25 shorted
to GND?
Yes
Disconnect CB1-CB4.
to GND?
Yes
No
C1 Board
Panel
No
Yes
No
D Board
Disconnect CB1-CB4.
to GND?
Yes
No
C1 Board
Panel
Disconnect D31.
Connect D32.
Is pin 5 CN P25 shorted
to GND?
Yes
No
Disconnect CB5-CB8.
to GND?
Yes
No
C2 Board
Panel
Dec 18, 2010 | Panasonic TH-50PX75U Plasma HDTV
My Toshiba P25 s526 will power on. The AC is connected. The ac and battery lights are on. The battery discharges and the unit turns off with in 2 min.
Ok take out the battery and plug the AC in and power on to see if it works. If it does then it shouldnt go off after 2 min. but if it doesnt power that means there is a problem with your AC that is why it turns off.
I hope this solution has been helpful.
Sep 26, 2010 | Toshiba P25-S526 Notebook
I need an A/C adapter for my P25-S5262 Satellite laptop. Online sellers keep sending me adapters with a plug that is too small for the power jack. The latest seller wants to know what the "psp number" is...
ah its because at 6 years old the
Toshiba power source and power input plug you seek
has been discontinued and not superseded
A35 19v 6.3a 120w is a rare power source
one on ebay seller USA list this unit suitable for your
Toshiba Satellite P25-S5262
http://www.ebay.com/itm/NEW-Toshiba-Satellite-P25-P15-Laptop-AC-Power-Adapter-Charger-A35-19v-6-3a-120w-/401167479005
if not correct as in picture
you need to keep a look out online for sale any
used P25-S5262 with working power source
Mar 08, 2017 | Toshiba Satellite P25-S5262 Notebook
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
My toshiba P25-S676/80 will not turn on. No
May be a bad power jack or the powercord/ac adapter may not be putting out enough power.Your powerboard may need to be replaced or even the button itself may not be getting contact to the board itself.
Jul 11, 2009 | Toshiba Satellite A60 Notebook
Toshiba TN50V71
Shorted horz. output transistor
Feb 09, 2009 | Toshiba TN50V71 50" Rear Projection...
Reset to factory setting
Hold stop button pressed in front of the unit, and press power on the front.
Jul 06, 2008 | Televison & Video
Ac led blue battery led amber will not power on
When The Light Is Blue You are getting Power To The Unit. Have You Tried removing the battery Leave The Power Cord Pluged Into The Side Of The Unit. Then Try To Power The Unit Up Again. If Nothing Happens. Chck The manual I Think There Is A Reset Button Somewhere On The Machine Most Toshibas Have Them Somewhere. Hope This Works
sosec
Mar 19, 2008 | Toshiba Satellite A105 Notebook
Will not power on
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the ... This will help verify that the strip or switch is not bad.
Click on the above link and follow instructions.Thank You, Please dont for get to Vote.
Dec 15, 2007 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite P25 Notebook Logo
100 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
