Question about Makita BBX7600 75.6 cc Backpack Blower
Makita instructions how to adjust valves on a makita bbx7600ca
  • Dennison Digges
    Dennison Digges Nov 27, 2013
    fires right up but will not blow hard and then it dies. put new plug filter cleaned fuel line and crab. shop said the valves may need to be adjusted anyone know how to adjust them?
  • 577 Answers
Did you try running it on half choke ? does it run anybetter ? also how old is the gas ? were the diaphrams nice and flexible in carb or stiff ?
Posted on Dec 01, 2013
How do I adjust the carburettor on my Makita DPC6200 saw
You only have to adjust it a small amount. Ring Makita tech on 01908 210710 they will help you.
Mar 18, 2014 | Saws
I have a Makita MAC5200 and the guage is showing 120PSI , tank has pressure, yet I can't get any air from valves. Any suggestions would be appreciated.
Plunger inside the regulator could be stuck or adjustment knob stripped. Let the air out of the tank and take the regulator apart, lube with light grease (no kit available for this reg.). The factory part is expensive so replace (if needed) with generic, careful with size however because there is not much room under the panel and between the gauges . Easy temporary fix. Remove the safety pop valve and install a tee (or check under the pressure switch for spare port) re- install pop valve on the tee fitting. On the second port of tee fitting install a quick connect valve for full pressure. Generic regulator is sold at Lowes that can be installed on the temporary port.
Nov 03, 2011 | Makita MAC5200 Electric Powered Air...
The sandpaper works its way off the machine almost immediately after turning machine on. We already checked to see if the paper was the right size. We also made sure the tightening lever was secure.
If this is a belt sander then they have a tracking adjustment knob. You will need to adjust it so that the belt stays on and doesn't want to walk off.
Jul 13, 2011 | Makita Tools & Hardware - Others
How do I adjust the rip fence on a 2703 table saw
Goto this link:
http://powertool.manualsonline.com/manuals/mfg/makita/2703.html
The instructions for adjusting the rip fence are on page 11
Feb 16, 2011 | Makita Garden
How do you set up a carb on makita chain saw
You provide no manual, I chose a "DCS34" a link follows: http://www.makita.ca/data/upload/tools/DCS34%20F-E.pdf
It lists no starting point for the "H" and "L" needle valves, I recommend 1.5 CCW from lightly seated. then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter and spark arrestor; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run. If the saw cannot exhale it cannot inhale.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 02, 2010 | Makita 33cc 14-Inch Bar 1.9 HP Gas Powered...
Makita MAC2200 runs fine (with new Manifold Switch and repaired power cord) but there is an air leak under the new manifold switch that seems to be a feature of the switch. When set to automatic, the...
I have worked on many makita compressors and have run-across this problem on a few of them. Your compressor has a check valve that is supposed to hold tank pressure after the switch reaches set pressure. There is an unloader valve built into the pressure switch that releases the pressure in the discharge hose after the unit shuts off. The unloader allows the compressor to restart with-out any pressure in the discharge line. If the brass check valve is leaking pressure back into the system, air will leak out of the unloader valve. Follow the discharge line to the tank and you will see the brass check valve. To test valve for fault, run the compressor till it builds around 80 psi and unplug the unit from the wall outlet. Remove the 1/4" hose connector from the check valve and check for air leaking out of the valve. If it is leaking you can order form www.toolpartsdirect.com. or call the makita 1-800 number. The price is about the same. Good Luck on your repair.
Mar 18, 2009 | Makita Air Tools & Compressors
Makita BBX7600 75.6 cc Backpack Blower Logo
125 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
