My Kenmore Front loading Tumble Action Washer will not tumble or spin. It will fill and pump out. What can the problem be?
  • 2 more comments
  • Wanda Gray May 09, 2009
    I can hear it fill but it makes a strange noise when it should be pumping out. It will not spin or tumble.
    This washer doesn not agitate it tumbles.
  • Wanda Gray May 11, 2009
    It is filling and pumping out water. It is not tumbling or spinning
    This is a Model 417 42042100 Front Loader Kenmore Washer.. It will fill and it will pump out the water. When it should be tumbling a quite humm is heard and the tub does not move.. When it should be spinning it makes a noise like the pump is working and the tub does not move. The belt is intact.
  • 15,935 Answers
Please use the "Continue with this expert" option and reply with the exact model # so I can give you more exact help.
It will be something like 110.9023784
More than likely - it is the speed control board if your dryer is a direct drive type - unless the drive coupling has failed.
Can you hear the motor start - but just not agitate? then the coupling is most likely to blame.
Is the motor clicking on at all?? If you hear nothing - the speed controller board is bad.
Reply with the model # and I can direct you to the exact part #s to order if you are planning on doing this repair yourself.
Thanks!!
Posted on May 11, 2009
  • blueextc3221
    blueextc3221 May 11, 2009
    CLICK HERE for all the parts diagrams for your washer.
    Have you observed the motor spinning - or any strange smells?
    The humming sounds like your motor is trying to spin.
    #18 on the backguard diagram is the timer - there are no parts on it that are repairable - it must be replaced as a unit.
    #19 on the tub Diagram is the Motor - This must be uncoupled and tested for proper operation.
    #4 on Cabinet diagram is the speed controller.
    Please first remove the pump from the washer and be sure there are no obstructions, and it spins freely by hand.
    Then we can go on from there.
    If you need help checking the pump - please let me know!!
  • blueextc3221
    if the humming noise is coming from the motor - a winding has failed and will need to be replaced (unless there is an obstruction in the pump - preventing it from spinning)
    Sergeant:
  • 322 Answers
Try dismanttling it. Try to see if it the spinner is still connected to the base. I suggest that you bring it to a technician.
Posted on May 09, 2009
  • 68 Answers
When did you purchase this item? It sounds to me like there is a problem with the agitator. When did this problem begin?
Tim
  • 413 Answers
Snaggs, If your model number begins with 417 it could be a couple of issues. Start with the drain pump. Remove the bottom panel and see if the pump is clogged with coins or debris. It will be on the right. Check the pump impeller. Have a bunch of towells handy as you will have a lot of water coming out at you. When you drop the bottom panel you will be able to see if the belt is on in back. If this does not clear up the problem, more than likley it will be in the motor control board.
Posted on May 08, 2009
Kenmore 3.5 cu ft front load quiet tumble action washer. Will not stop cycling, leaks, and shakes violently when spinning.
The shaking could be due to a defective drum support bearing. The shaking also could have caused the door seal to fail, resulting in the leak.
Jan 22, 2014 | Kenmore 3.5 cu. ft. Front Load Electric...
Continues to thumping sound only on the spin cycle on my tumble action washer (front loader).
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 15, 2011 | Kenmore Kitchen Ranges
I have a kenmore washer that does not drain and spin at the end of the wash cycle....Kenmore Super Capacity 3.5...Quiet Tumble Action...Easy Access
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 02, 2010 | Frigidaire ATF6000ES Front Load Washer
We have a Kenmore 3.5 Super Capacity Quiet Tumble Action Wash Easy Access. The spin cycle works however the water won't drain and our laundry is soaked. Help...
It could be either the pump or a clog in the discharge hose. Take a shop vac and attach it to the discharge hose to remove the water from the machine. Remove the pump housing and run a wire down the discharge hose to check for a clog. If there is no obstructions, reattach the pump housing and remove the pump motor. Run a spin cycle and see if the pump motor turns.
Aug 27, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Will not spin or drain
take front panel off in the water pump rubber hose feel to see u can feelsomething in side the pump .this will cause the pump to stop/and not spin
May 12, 2009 | Kenmore HE2 Plus Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore front Loader 41729042990
remove motor, check carbon brushs,replace if short,the manual may help.motors that have brushs are the principle,sole motor is Italian,yours is German,anyway thats beside the point ,its the brushs.buy ,eire
Dec 11, 2007 | Kenmore 44102 Front Load Washer
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Kenmore front load tumble action washer
Snaggs, If your model number begins with 417 it could be a couple of issues. Start with the drain pump. Remove the bottom panel and see if the pump is clogged with coins or debris. It will be on the right. Check the pump impeller. Have a bunch of towells handy as you will have a lot of water coming out at you. When you drop the bottom panel you will be able to see if the belt is on in back. If this does not clear up the problem, more than likley it will be in the motor control board. Catriver...post back.
Sep 23, 2006 | Kenmore 43142 Front Load Washer
Washing Machines Logo
77 people viewed this question
Top Washing Machines Experts
