Question about Radio Communications
Motorola r765is RADIO TRACKING
What will cause disc error on the motorola dcp 501
Either a dirty laser, faulty tracking mechanism, or a weak laser(aging) will cause unit to mistrack. When this happens the mechanisms are replaceable and not repairable.
Mar 30, 2014 | Motorola DCP-501 Receiver
Does anyone know the battery life for the Motorola GPS fitness tracker?
From what i've read about it, you can get about 5 hours of outdoor tracking and 10 hours in indoor activity tracking.
Good Luck
Mar 06, 2014 | Motorola Mobility 16GB MOTOACTV GPS...
Gps tracking solutions
does not work inside buildings, must have clear sky
just buy one of these options
QA03185AA
QA00177AA ENABLE GPS FEATURE
Nov 27, 2013 | Motorola Radio Communications
How do i get my motorola r765is to stop beeping
It beeps when it loses signal then reconnects to the network. I have not figured out how to stop it yet but if I do I will post the solution here if anybody knows how to turn off that notification please help before my company radio has a terrible accident.
Apr 06, 2012 | Cell Phones
Want to know if radio shack makes a handheld scanner that can be used to track dogs
No. Dog tracking systems operate in the 216 to 220 MHz range, frequencies that are allocated to Amateur radio and telemetry/radio location, and scanners do not cover these frequencies. Even if you could receive the signal, all you would hear is digital hash/noise that would not give you any tracking/location information. The tracking systems only work with their dedicated receivers/display units.
Feb 17, 2011 | Radio Shack Pro-99 Handheld Scanner
How do I program it for triple truncking?
There is no such thing as "dual trunking" or "triple trunking." Such terms are used by manufacturers to indicate the number of trunking systems that a scanner is capable of monitoring. The PRO-95 is designated as a Dual Trunk-Tracking scanner because it is capable of monitoring both Motorola and EDACS systems. Programming a trunking system in to a scanner is a detailed process that requires a bit of research.
For details on active trunking systems in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Once you have the system information you can follow the programming steps outlined in your scanner's operating instructions. If you don't already have the manual, you can download and print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-95/pro95.pdf
Bill B
Jul 24, 2010 | Radio Shack Pro-95 Handheld Scanner
Need a tracking program on the radio
What do you mean tracking program as in callsigns, memory or what
Oct 26, 2009 | Vertex FNB-40, YAESU,FT-10R,FT-40R,FT50,...
I have 4 motorola walkie talkies but no
The Motorola GP340 radio is a dealer programmable radio. It requires a cable, radio interface box and Motorola proprietary software (which is available by subscription to dealers and qualifying entities).
Oct 13, 2009 | Motorola Walkie Talkie 2-Way Radio
CD player not tracking right
These are the early signs or optical lens assembly failuer. i would start preparing to replace this assembly. the tracking motor and rail are damaged.
May 28, 2009 | Audio Players & Recorders
Mobile tracking software!
you can call your service provider and see if they carry the program or you can try google.
Aug 13, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Radio Communications Logo
74 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
