Question about Kirby G6 Bagged Upright Vacuum
Green light doesnt come on - Kirby G6 Bagged Upright Vacuum
  • Kirby Master
  • 18,402 Answers
Replace the belt it must be broke
Posted on Nov 30, 2013
My dc59 doesnt work green light flashes when you press start button
Hi there, it's Jack at Dyson.
A green light flashing when you try to use your DC59 could mean the battery has no power. If you're confident it's been allowed to charge for at least 3.5 hours, it's possible that the charger cord isn't connecting correctly with the machine itself, so no power is reaching the battery. This is more likely to occur if you're recharging the machine in the docking station, and the charger cord isn't correctly positioned.
We're happy to help you check for and resolve this - if a replacement part is needed we can also confirm if this is covered under our 2-year parts and labour guarantee. When you have your machine to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 27, 2014 | Dyson DC59 Animal Bagless Cordless Stick...
Green light kirby vacuum
The green light does not affect the performance of your vacuum. There is a small magnet in the brush roll that makes the light glow to show you the brush is spinning properly. If your light worked before you took the vacuum in for service you can look at the brush roll to see if it has been installed properly. The magnet should line up to spin at the spot where the green light is. If the brush is not installed properly or the wrong brush roll is installed the magnet will not line up with the green light.
Mar 03, 2014 | Vacuums
The suction comes on but the motor doesnt turn the beater bar nor does the red or green light come on
check to make sure power is coming from wall with a voltage meter, if not wiring issue or blown motor or wiring around beater motor
Feb 28, 2014 | Lindhaus Vacuums
Green light mean
The green light blinking means the belt so slipping. The green light being off means the brush is not spinning at all. The belt needs to be replaced at least twice per year for proper agitation.
Jan 04, 2014 | Kirby Vacuums
Green light
You are referring to the green led light on the front of the machine that tells you the brush is rotating? this is operated by a small magnet on the brush roll, when rotating it generates a small current to bring the light on. Remove the brush roll and check for damage behind the green led inside the case, also check for the magnet on the brush roll, ensure it is not missing and the brush roll is in the correct way round, magnet needs to be at green led end (ie to the left)
Magnet is fitted flush within the brush roll close one end and is around 6mm 1/4" diameter.
Green light not working will not affect the machine in any way.
Aug 29, 2013 | Kirby Generation 3 Bagged Upright Vacuum
Roomba 4106 new battery charged but wont start
see the diodes, resistor, capacitor inside for test.
since the battery is new, the power charger is faulty, power regulator IC is bad.
God bless you
May 16, 2012 | Roomba 3005 Pro Robotic Vacuum
Roomba Discovery SE Bagless Robotic Vacuum: My Roomba battery charger has no lights and does n...
use a multimeter to test if it is actually putting out a charge. Is this a regular roomba charger with the green led on top? And it just doesnt light up anymore? If so then the pack is dead. replace it.
May 16, 2010 | iRobot Roomba Discovery SE Bagless Robotic...
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
Do i want the green light on or off on kirby upright
It has nothing to do with the green light. Green light simply indicates that brush roll is spinning. If there is no green light:
1 - belt may be broken
2 - Improperly installed nozzle
3 - wrong brush roll is installed
Properly adjust the nozzle - turn the Kirby on. Keep lowering the nozzle till it touched the carpet and you will hear change in sound. Then lower it by one more click.
Rocky
(GoodVac.com)
Mar 30, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Shark professional model 505.
It sounds like the themostat inside the unit is broken. The only solution to fix the unit is to send it to the manufacturer for repair.
I'm unsure of the cost for the repair but it might be cheaper if the unit is older to throw it away and buy a new steamer.
Sep 02, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Kirby G6 Bagged Upright Vacuum Logo
16 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
