Question about Maxi-Cosi Familyfix Base Isofix only
Maxi cosi familyfix beeps at testing, because the isofix wire to the tester is broken. How to dismantel the familyfix to repair the broken wire at the slider leg?
Babycare_nl
  • 21 Answers
SOURCE: maxi-cosi priorifix - fitting with seat belt
Sure!
Please download the manual via this link.
The instructions are on page 10, paragraph D
http://www.maxi-cosi.nl/media/producthandleidingen/maxicosi/PrioriFix.pdf
With kind regards,
www.babycare.nl
Erwin de Raad
Posted on Jun 24, 2009
SOURCE: Lost one of the yellow connectors for isofix for Maxi-Cosi Priori
The 'Isofix guides' are available to buy from Dorel UK LTD (01842 767965) (See maxicosi website/customer services) for £7.99+P&P @ £3.99.
When I called (as one of mine is broken) they told me they are not essential to fit the car seat safely - they are simply 'guides' and if the actual forks on the seat are not damaged in anyway; not having the guides will not affect the car seat performance in any way.
Kindest regards
Glitterbabe628
Posted on Jul 29, 2009
  • 419 Answers
SOURCE: Maxi cosi tobi plastic part replacement
If you contact www.maxi-cosi.com you will be able to order this part.
I hope this helps.
Posted on Sep 15, 2009
  • 419 Answers
SOURCE: what's the difference between Easybase (non
The Easy Fix Base is used for cars which have isofix points in their car. The Easy Base fits into your car using the seatbelt.
Both of these bases can be used ONLY for the CabrioFix Carseat and cannot be used for the next stage seat (Group 1).
I hope this helps.
Posted on Oct 12, 2009
  • 286 Answers
SOURCE: Can a maxi cosi cabriofix
hi yes you can here is a video showing you how to fit in a car
http://www.youtube.com/user/Kiddicare#p/search/17/vO51Ev2c2Ok
Posted on Feb 17, 2011
Is the Maxi-Cosi Pebble (UK Spec) comparable with the 2007 Honda Element (US Spec)?
I don't really know about the Honda element but I do know the maxi cosi is one of the most popular, reliable, trusted, affordable and safest car seats on the market.
Mar 03, 2015 | Maxi-Cosi Familyfix Pebble Group 0 Carseat...
Isofix base beeps and third green light goes out when driving around corners/over bumps?
Hi
This would indicate that the unit is loosing connection when you go around corners / over bumps. The only time we've heard of this before is when driving is at high speed.
If you're finding this an issue at low speed we would recommend the unit comes in for inspection / repair.
Oct 23, 2013 | Maxi-Cosi Familyfix Base Isofix only
How to remove the isofix base from the car seat
Hi
Is it removing the carseat from the base or removing the base from the car that you're having difficulties with?
Feb 03, 2013 | Maxi-Cosi Familyfix Base Isofix only
Maxi-Cosi Familyfix base Isofix base warning beep
Yep, there's a switch underneath to turn off the sound, but the lights will still work.
Jan 31, 2013 | Maxi-Cosi Familyfix Base Isofix only
My family fix isofix keeps beeping (green lights)
Hi
It could be that it has accidentally been put into test mode.
To run the test mode you hold in the long thin black button just under the display. Once the sequence starts let go of the button and it will cycle through the different lights and then they will all go out. That's when the test mode has finished.
The base should now stop beeping.
If this does not work it will need to be sent in for inspection.
If you're in the UK and the product is under 2 years old, please contact your retailer with your proof of purchase and they can arrange for it to be sent to our engineers for inspection / repair work required under warranty.
If you're in the UK and the product is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to discuss booking it in for chargeable inspection / repair work required.
If you're outside the UK please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab on the right side for your enquiry to be sent through to the customer care team in your country.
Nov 23, 2012 | Maxi-Cosi Cabriofix Car Seat and Isofix...
I have Broken the handle on isofix base which releases the seat. Where can I take it to get it fixed?
Hi
Nov 07, 2012 | Maxi-Cosi Familyfix Base Isofix only
How do I release the maxi Cosy cabrio from the family fix isofix
Press the button on the front of the FamilyFix base and it will release the carseat.
Mar 16, 2012 | Maxi-Cosi Baby Gear
I have a maxi cosi cabriofix and need a base to go with it. Which base fits this model? What is the difference between the easy base and easy fix? My car does not have the iso fix adaptors so that will...
The Maxi Cosi CabrioFix can be fitted using the EasyFix base (IsoFix or seatbelt fitted) the EasyBase and EasyBase 2 (fitted with seatbelt only) or the FamilyFix base (IsoFix only). If you do not have IsoFix points you need either an EasyBase or EasyBase 2 to be fitted with seatbelt.
Sep 25, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi-Cosi Familyfix Base Isofix only Logo
215 people viewed this question
Top Maxi-Cosi Baby Gear Experts
Dorel UK
Dorel UK
Kristy Richie
Kristy Richie
Level 1 Expert
Bear Mark
Bear Mark
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
