Question about Pool & Spa
Hello, I have pentair minimax 250 pool heater. When turning on the temperature, ddtc cycle to off. Nothing happen, no clicking noise, blower doesn't turn on , no error code on LCD. No led light in the back of ddtc. 1 flash on ignition module . Please help
    Champion:
  • 305 Answers
Check main power supply for proper voltage, check primary and secondary sides or transformer, 24 vac getting to display screen???? 120 vac getting to blower???
Posted on Dec 05, 2013
  • 22 Answers
SOURCE: i have a Pentair MiniMax NT 250,000 btu pool heater that fails to
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Posted on Dec 21, 2008
  • 61 Answers
SOURCE: Pool heater will not heat
Im no pro, but I know there is an air sensor behind the main board. If the fan is running you probably have a problem with that sensor. If your lucky the air hose could have just popped off.
Posted on Apr 04, 2009
  • 128 Answers
SOURCE: minimax pool heater cuts out at 91 degrees when remotely set for
Check the temp reading on the heater. It is probably set at 91...heater control should be set to 104
Posted on Aug 30, 2009
  • 246 Answers
SOURCE: Pentair Minimax 250M
how many times it blink will tell you what is wrong check at the codes. unplug thermostat check fo homs 10 k around is fine at 80 degrees pressure switch require a by pass but DO NOT RUN THE HEATER WITH A BY PASS ANY CONTROL!!!!
Posted on Sep 19, 2009
SOURCE: Pentair minimax pool heater (1 year old)
Board problem? Did you fix the problem?
Posted on Oct 19, 2009
Pentair 250 pool heater
check gas pressure and when it goes out check voltage from transformer
May 28, 2013 | Pentair 250k Minimax Ch Ng Mv Heater
Pentair Pool Heating Rapidly Increases Temp on Panel then shuts off.
Check the Thermal Reg in the header and also make sure you have adequate water flow thru the heater, make sure your filters are clean and there are no external by-pass valves open.
If you remove the Thermal Reg in the header and the heaters seems to run fine the replace with a new one.
May 03, 2017 | Pentair Minimax NT Heater
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
DDTC reads off at all times even when pool is circulating. It usually reads the pool temperature. Also, i don't have a green pressure LED. Can't start the gas heater either.
If you have a control system (i.e...aqualink) controls on the heater should be set to remote. If that is the case and it still gives no temp reading, it is the thermistor (temp sensor). it is very common for rats to chew through the wire.
Oct 13, 2011 | Pentair Minimax NT Heater
Heater will not turn on.
If the heater does not even attempt to light, it's most likely the Digital Display Temperature Controller (DDTC) Circuit Board.
Nov 08, 2009 | Pentair Minimax NT Heater
Pentair Minimax 250 does not light everytime
that one think thats bad with pentair heaters they say when you turn one on stand to the right cause the door can blow off because the way there burner are set up u need to take out the burner trays and clen them this problem does not happen with raypak heaters
Apr 18, 2009 | Pentair 250k Minimax Ch Ng Mv Heater
Pool & Spa Logo
63 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
