Question about Kirby G6 Bagged Upright Vacuum
Green light doesn't come on - Kirby G6 Bagged Upright Vacuum
    Genius:
  • Kirby Master
  • 1,239 Answers
The green light means the brush is spinning. Your brush roll may be bound with hair or debris and/or your belt may be stretched out and not spinning the brush fast enough. Belts should be replaced at least twice a year.
Posted on Dec 04, 2013
Green light kirby vacuum
The green light does not affect the performance of your vacuum. There is a small magnet in the brush roll that makes the light glow to show you the brush is spinning properly. If your light worked before you took the vacuum in for service you can look at the brush roll to see if it has been installed properly. The magnet should line up to spin at the spot where the green light is. If the brush is not installed properly or the wrong brush roll is installed the magnet will not line up with the green light.
Mar 03, 2014 | Vacuums
Green light mean
The green light blinking means the belt so slipping. The green light being off means the brush is not spinning at all. The belt needs to be replaced at least twice per year for proper agitation.
Jan 04, 2014 | Kirby Vacuums
Green light
You are referring to the green led light on the front of the machine that tells you the brush is rotating? this is operated by a small magnet on the brush roll, when rotating it generates a small current to bring the light on. Remove the brush roll and check for damage behind the green led inside the case, also check for the magnet on the brush roll, ensure it is not missing and the brush roll is in the correct way round, magnet needs to be at green led end (ie to the left)
Magnet is fitted flush within the brush roll close one end and is around 6mm 1/4" diameter.
Green light not working will not affect the machine in any way.
Aug 29, 2013 | Kirby Generation 3 Bagged Upright Vacuum
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
Start button doesn't work
test the switch.
see the diagram below. God bless you
if the switch is o.k 2) test for continuity the wires 3) Test the motor input voltage motor. 4) Test the power cord for break or loose wires with VOM
May 24, 2012 | iRobot Roomba 530 Robotic Vacuum
EVERYTIME I PUSH THE BUTTON REALLY LOW TO ALLOW THOROUGH CLEANING IN THE CARPET, THE LIGHT DOESN'T TURN ON AND IT DOESN,T **** THE DIRT AT ALL.. IT ONLY WORKS IF YOU PRESS IT UP ONCE BUT IT DOESN'T GET ALL...
You need to replace the belt whenever the green brush indicator light goes out or is not steady. Be sure to observe the wear settings when re-installing the brush. The ends of the brush are marked with 1, 2, or 3 notches and numbers. In normal use the brush should have setting # 1 towards the rug. These settings adjust the brush for wear, and moving the bristles out prematurely will result in excess brush and belt wear.
Feb 24, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Brush roll won't turn on for the shark NV22L vacuum. the light on the brush roll is dark, not red or green
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
Feb 10, 2011 | Shark Helmet NV22L Shark Navigator Upright...
Do i want the green light on or off on kirby upright
It has nothing to do with the green light. Green light simply indicates that brush roll is spinning. If there is no green light:
1 - belt may be broken
2 - Improperly installed nozzle
3 - wrong brush roll is installed
Properly adjust the nozzle - turn the Kirby on. Keep lowering the nozzle till it touched the carpet and you will hear change in sound. Then lower it by one more click.
Rocky
(GoodVac.com)
Mar 30, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G6 Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
