Question about Sony KP-51WS500 51" Rear Projection Television
Colors out of alignment and screen bending
I have the same problem it seems as a few other people here.
 I have a 4 year old st and all of a sudden I noticed the colors out of sync and the top and lower screen bending.
 I have removed the rear cover and cleaned the lenses and tried to adjust one with the wing nut didn't make any difference.
 Can i fix this myself or do I have to call in help?
 Thanks
 john
  • 105 Answers
The wing nuts you moved are for focusing the lens. more than likely you will need to replace the stk ics in your tv they are located on the signal board with 2 large heat sinks. they should say stk392-??? i do believe it is stk392-510 for sony. all you need to do is replace these and should be good to go
Posted on Oct 12, 2007
SOURCE:
Yellow Tint over picture...
well..it's simple really...yellow is from a degrading video unit and system board..so, you'll find that it's high time for a major service situation.
May 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
My picture is warped or bending in the middle
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 21, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color alignment
This sounds like a convergence problem. Would you describe the picture like a 3-D one? If you can solder, you should be able to fix this yourself. Let me know if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Mar 26, 2009 | Hitachi 57F500 57" Rear Projection...
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Philips Rear Projection Issue with Color Alignment.
this seems to be convergence problem in your tv .............
Aug 23, 2008 | Televison & Video
Mitsubishi WS-55809
Harker, the convergence circuit has failed, IC`s and possibly a couple of support resistors, that`s a good set, call around to your local shops and get a few estimates, waay better set than the new dlp and lcd sets in my opinion, any questions? e-mail me back, Happy Holidays, BMW Rider
Dec 10, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Image is totally distorted
Did you also replace the bias resistors required when you converted from STK392-110 to the higher STK392-xxx modules? If I wer you I would go back to the orginal modules only new ones. Then I would also get a schematic to test the voltage levels on the chips to make sure they are the same as on the schematic.
Jul 28, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
