Question about MSI Computers & Internet
E system 1412
Cmos battery location
    Renaissance:
    An user who is expert in 3 categories / brands.
  • MSI Master
  • 2,226 Answers
It looks like a big round size of a penny silver looking.
Posted on Nov 29, 2013
Windows password reset 9.0 download
Remove CMOS battery. Removing the CMOS battery like the one shown in the picture causes the system to lose all CMOS settings; including the password. To do this, locate and remove the CMOS battery from the motherboard for at least five minutes, then replace the battery and turn the computer back on
Jul 06, 2016 | Computers & Internet
Where is blinking amber light located on dell
Replace CMOS Battery.
1. Locate your CMOS battery
2. Obtain battery information
3. Removing the battery
4. Removing the battery
5. Enter CMOS values
This link will guide you. CMOS
Thank you for posting..
Jun 30, 2011 | Dell OptiPlex GX520 PC Desktop
Where is CMOS battery located on system board?
CMOS battery located on system board & looks 1 rupee coin
Feb 11, 2011 | HP Compaq d530 SFF PC Desktop
I can not downloads software and maps for my magellan 1412. Why is that?
GPS SYSTEMS HAVE A TENDENCY TO LOSE CONNECTIVITY TO SATILLITES BECAUSE OF BAD WEATHER, CLOUD COVER, TUNNEL ENTRANCE, BAD OR NO POWER, BATTERY LIFE HAS BEEN EXPENDED, HAZARD OF ELECTROMAGNETIC INTERFERENCE TO GPS SYSTEMS, AND IMPROPER VEHICLE MOUNTING AND HAND HELD POSITION. FREE SOLUTIONS 1. ALWAYS PLACE YOUR GPS DEVICE IN THE UPPERMOST PORTION OF YOUR VEHICLE SO THAT THE GPS SIGNAL MAY EASILY LOCATE YOUR DEVICE EVEN WHEN THE WEATHER IS BAD 2. KEEP YOUR BATTERY CHARGED ONLY WHEN IT NEEDS IT MOST AND AVOID CHARGING OFTEN 3. IF YOU OVERCHARGE YOUR GPS DEVICE, YOU WILL EXPERIENCE BATTERY LEAKAGE, WHICH CAN EAT AWAY AT YOUR CLOTHING, DESTROY YOUR DEVICE IN SECONDS, AND CAUSE DAMAGE TO YOUR VEHICLE SEATS 4. YOUR GPS DEVICE HAS A TENDENCY TO FREEZE BECAUSE OF THE SIM AND MEMORY CHIPS LOCATED WITHIN IT 5. YOU CAN FIX THE FREEZING PROBLEM BY REMOVING THE SIM CHIP AND MEMORY CHIP AND RESTARTING YOUR SYSTEM 6. OTHER FREEZE PROBLEMS OCCUR BECAUSE THE DEVICE IS COLD WHEN IT IS KEPT IN THE VEHICLE AND CHIP CREEK OCCURS WHERE THE DEVICES MICROCHIPS BECOME LOOSE AND TIGHTEND BECAUSE OF WARM AND COLDER AIR FLUCTUATIONS. IT IS BEST TO KEEP THE DEVICE IN A PURSE OR ON A TABLE WHERE IT IS NOT SUBJECT TO CONSTANT TEMP. CHANGE 7. PREVENTION OF ELECTROMAGNETIC INTERFERENCE IS BEST SOLVED BY: interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common
Jan 21, 2011 | Magellan RoadMate 1412 Car GPS Receiver
P5RD1-V BOOT PROBLEM
The CMOS, which stands for complementary metal-oxide semiconductor, is the hardware component of a computer that supports the BIOS, or basic input output system. The two terms are often used interchangeably, and the two technologies work together to perform the same basic function. They maintain the low-level settings on a computer, letting the computer know, even before the computer's operating system starts, what kinds of hardware the computer has available, such as hard drives and video display adapters. A special battery located on the computer's motherboard powers the CMOS. To reset the CMOS on a Dell computer, briefly remove and then replace the battery
  1. Turn off the computer. Disconnect all cables and detach all devices, including USB devices, from the computer. Press and hold the computer's power button for 10 seconds after it has been unplugged. This grounds the system board.
  2. Step 2 Remove the computer cover. All Dell systems have a cover panel on the chassis that you can remove so that you can access the system's motherboard and internal components. For some Dell computer lines, such as OptiPlex, the computer cover is held in place by a release latch located on the back of the computer. Pull the latch to release the cover and then slide the over up and away. Other lines, such as Dimension, have large, slotted thumbscrews. Turn the screws counter-clockwise until they disengage from the chassis, the slide the cover off the computer. Dell computers often ship with the computer's user guide in CD form or with the guide pre-loaded on the system's hard drive. You can locate the instructions for removing the cover from your particular system in the user guide.
  3. Step 3 Locate the CMOS battery on the system's motherboard. CMOS batteries range in size from size and thickness from about the size of a nickel to about the size of a quarter. The CMOS battery will generally be labeled CMOS on the motherboard and will be the only battery openly exposed on the motherboard.
  4. Step 4 Remove the CMOS battery by prying it gently up out of its socket. The sockets are specifically designed to allow the battery to be replaced.
  5. Step 5 Wait 30 seconds, and then replace the battery in its socket. This will reset the CMOS. Replace the computer cover to complete the process.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 14, 2009 | ASUS P5RD1-V Motherboard
My Magellan Roadmate 1412 does not seem to charge. I cannot use the device unless it is plugged into a wall outlet or car charger. Does this model not have a battery? Please help. Thanks!
does it appear to be charging when its plugged in....go to the system folder then the power option..the power bar should be moving left to right...if its all green and its not scrolling left to rigth , its receiving power but not charging. possibly because the charge port is damaged or the battery is either shot or disconnected.
Jun 24, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Computers & Internet Logo
19 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
