Question about Sony Drbt101 Stereo Bluetooth Wireless Hands Free Headset Dr-bt101 Drb-t101
Access DR-BT1010 battery pack
How do I access the battery pack in order to replace the batteries which will not recharge
2 Suggested Answers
  • 22 Answers
SOURCE: how do you open a battery pack to put in new batteries
You do not. You will have to replace the entire battery pack. Modern laptop battery packs ave circuits in them that prevent over charging and other nasty habits that batteries used to have. For instructions on removing the battery pack, check HERE. New batteries can be ordered here and here.
Posted on Jan 04, 2012
Time keeps changing on my vetch DS6722-3. How do I correct this?
1.) The handset battery pack has to be properly charged in order to set any of the handset settings...if the battery pack in the handset is not holding the charge ~ then
2.) The rechargeable battery in the handset is at its end of life and will need to be replaced.
Jan 18, 2017 | Lands Phones
How do you open a battery pack to put in new batteries
Jan 04, 2012 | Sony VAIO VGN-NS135E/S Notebook PC
How to access the battery on an iphone?
iPhone has an internal rechargeable battery. The iPhone battery isn't user replaceable; it can
only be replaced by an authorized service provider. For more information, go to
www.apple.com/support/iphone/service/battery.
Oct 04, 2010 | Apple iPhone (16 GB) Smartphone
Can i and how do i change a rechargeable battery on a Remington 9100? Where can i buy the battery assuming this can be done
You will find batteries at shaveroutlet.com. I have provided links below. Your shaver has either NiCd or NiMh cells. You will need to order the correct type and you will need to order two batteries
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
or
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
To change them you will need to remove the back cover. There are 3 screws. 2 can be easily seen. The third is under the trimmer wher it hinges to the shaver. You will need to carefully pry out the trimmer to get to it. Once screws are removed, you can take off the back. Inside, remove the metal clip to access the batteries better. Then, unsolder the wires from the battery tabs. Install new batteries by soldering to wires. Reassemble in reverse order
Sep 22, 2010 | Remington Health & Beauty
Can you take the Swivel Sweeper battery pack apart to replace the batteries with new rechargeable batteries? Batteries look like AA or AAA, but it appears that the battery pack is sealed. Is there any way...
Yes you can if you have a way to cut through the plastic outer case,(I used a Dremel rotary tool). Inside you will find six double A Ni-mh batteries. I found eight of these for sale on ebay for around ten bucks,then all you do is solder some wire to the batteries like the original battery pack and tape up the case and charge.
Nov 20, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Replacement battery for Coby TF-DVD7005 DVD Player.
need a coby rechargeable batt pac. Where can I get it and how much is it?
Oct 31, 2008 | Coby TF-DVD7005 Portable DVD Player
Dvd battery
Hello sara_lou,
I have 2 suggestions for you:
1) Look into purchasing an external rechargeable battery pack for PDVD units (available at Best Buy). It is an external pack that will connect to the players AC port.
2) Prepare for surgery! You will need 6 rechargeable AA batteries, a soldering iron, super glue, and patience.
You'll need to open the battery case and look at the batteries within. Note the direction and polarity of all the batteries and how they are wired/soldered together. You will need to replace all these batteries with the new ones you have purchased. Wire together the new batteries in the exact same order and polarity as the old dead ones. Remove the old ones and replace with the new ones. Solder in where necessary and be sure not to bridge any contacts. Put the case back together with a little super glue on the seam. Replace into the PDVD player when the battery case is dry (or else you may permanently mount the battery case into the player) and set to recharge using the AC pack. if everythign was wired correctly, you should have a charged battery pack in about 1 hour (since most rechargeable batteries come with 3/4 charge in them).
While I don't recomend this second solution, it is plausable for the hobbiest electrician or DIY-er.
Best of luck to you!
Jul 20, 2008 | Insignia IS-PDVD10 Portable DVD Player
Rechargeable battery does not recharge
They are nickel cadminum batteries, and are replaceable, you may have to order from a repair shop, or go thehooverstore.com. Once you have the battery pack out, maybe you can find them like at Radio Shack or other places that sell these type packs,
Oct 15, 2007 | Hoover S2105 Slider Bagless Stick Vacuum
Sony Drbt101 Stereo Bluetooth Wireless Hands Free Headset Dr-bt101 Drb-t101 Logo
23 people viewed this question
Top Sony Radio Communications Experts
 Grubhead
Grubhead
basssplayer
Level 1 Expert
Piyal Perera
Piyal Perera
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
