Causes slow - Computers & Internet
    Novelist:
  • 288 Answers
Below are some reasons for computer running slow:
- Lack of Windows Updates
- Low RAM.
- Background services is activated.
- Corrupted registry.
- Installed Programs or Games that is not compatible with your computer.
- Infected by Virus/ Malware.
Possible solutions to speed up PC performance would be:
- Install latest Windows updates.
- Upgrade RAM.
- Disable background services.
- Uninstall unnecessary programs and files.
- Fix registry error with reliable program like I always use RegInOut.
- Install a good antivirus.
Posted on Nov 28, 2013
Why hp g62 hang & very slow
Hi, there. There are a number of reasons that may causing your HP computer running slow, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/fix-slow-hp.html to free diagnose and fix related issues. Hope it helps. regards!
Feb 16, 2012 | HP G62144DX Laptop
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Why hp g62 hang & very slow & heat
There are a number of reasons that may causing your HP G6 computer running slow, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/fix-slow-hp.html to free detect and fix related issues. Good luck!
Choking and soonly acceleration.
There are 2 things that come to mind that can cause your issues.
1. Idle air control sensor. This can cause bad air/fuel mix ratio. ( bad idle, slow acceleration )
2. Throttle position sensor, ( TPS), This can cause a bad idle and slow acceleration.
I hope this helps.
Jan 30, 2011 | 2006 Chrysler Sebring
My hp pavillion is running too slow.
Well, there are a number of reasons that may causing your HP pavilion running slow, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/ to free detect and fix related issues.
Jul 20, 2010 | HP Computers & Internet
Cpu running slow, even causing audio to chatter.
Yes it may affect your speed so whenever you sit on your pc just clean temporary file
  • start
  • run
  • type %temp%
  • tap enter and delete all the files
by this the speed can be improved
May 14, 2010 | Computers & Internet
Runs slow on video downloads
Hello Sir,
downloading speed depends on internet connection not on PC specification.
If your transfer is low then downloading will also be low.
Take note that source from which you are downloading also must have reliable connection.
cheers,
Mike
May 08, 2010 | Gateway 832GM PC Desktop
94 acura legend idles fast and slow when initally starting
The butterfly valve inside your throttle body may be loose causing your idle problem. have it inspected to see if it is.
Sep 07, 2009 | 1994 Acura Legend
Running slow Aspire 3680-2682
in your case it could be your battery is bad.
battery can cause alot of strange thing.
from slow to touchpad/keyboard not working.
But most of the slow problem it cause by
1. memory.
Make sure you have enough memory
2. software.
Tried to re-install the operating system.
3. defective harddrive.
May 04, 2008 | Acer Aspire 3680 Laptop
Games run very slow after lightening incident
Lightning can cause weird problems, All you need is "Static Discharge" every capacitor in your PS2. It's not recommended for you to do it by yourself. So a technician help is needed. Good Luck
Jun 08, 2007 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
David Payne
David Payne
