Question about Imperial IR-6-C Elite Gas Kitchen Range
Oven does not heat up - Imperial IR-6-C Elite Gas Kitchen Range
Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
Frigidaire pleb30t9fcc double oven -- top oven heats fine --- bottom oven does not heat up all the way
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
heatman101
May 14, 2010 | Frigidaire PLEB30T9FC Stainless Steel...
Oven not properly heating
heatman101
May 06, 2010 | Viking 30" Professional Select Built-in...
We have a GE JKP15 oven that will not heat to temperature (350F) when first turned on. The oven will beep (temp confirmation) and the display will indicate 350F but the oven temp will only be at 220F...
heatman101
Dec 26, 2009 | GE JKP15 Electric Single Oven
Top oven works fine bottom oven won't heat
heatman101
Dec 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Oven heating up slow
heatman101
Nov 23, 2009 | GE Profile JTP18 Electric Single Oven
Upper oven will not heat above 250 , lower oven works fine
heatman101
Jul 29, 2009 | Jenn-Air JJW8230D Electric Double Oven
The oven stopped heating but the convection oven function works
heatman101
Jun 23, 2009 | GE Profile JTP18 Electric Single Oven
OVEN TURNS ON BUT WONT HEAT UP.
heatman101
Aug 25, 2008 | Whirlpool RBD305PD Electric Double Oven
GE Double Oven JKP45BA, lower oven wont heat
heatman101
Jul 30, 2007 | GE JTP48 Electric Double Oven
Imperial IR-6-C Elite Gas Kitchen Range Logo
20 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
starztruck4u
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
