Question about HP Designjet 5500PS 42 Printer Open Box
HP Designjet 5500 carriage belt is off the pulley roller, how do I get it back on?
Go to a store and ask them for to put it in it place again
Posted on May 08, 2009
Carriage belt has two types of corrugations which is to be fixed underneath the carriage and belt is shifting from pulley what is to be done
The part of the belt with the teeth goes toward the motor. The transition part of the belt (where the belt goes from teeth to ribs) goes under the carriage.
Oct 06, 2013 | HP DesignJet 500 InkJet Printer
Hp designjet 1050c check printhead path (1) but the carriage barely moves?
Either the belt pulley is broken, or installed incorrectly, or the belt was installed backwards.
Dec 26, 2012 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 500 carriage assembly it's vibrating
Get carriage assembly out from the service station area, remove right door, check right side pulley of carriage belt, weather its cracked or dirt particles deposited on it, clean/replace it, lubricate carriage rail, fix back every thing check .. best of luck.
Nov 26, 2012 | HP DesignJet 500 InkJet Printer
I have problem with my 5500 hp: check printhead path 2
The most common cause of the Check Print Head Path Error 2 is a worn out carriage belt. Open the top cover and locate the carriage belt. It is the long thin belt that extends the full length of the plotter. Use a light and look under the belt for debris that looks like pencil erasure crumbs. If the crumbs are there, the belt is disintegrating and needs to be replaced. See: http://www.lpscomputer.com/c-732-designjet-5000-5500-belt.aspx
Dec 01, 2010 | HP Designjet 5500 (42 in.) InkJet Printer
Need instructions to replace carriage belt for hp designjet 500, specifically how to remove and replace on the carriage assembly
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
Jul 12, 2010 | HP DesignJet 500 InkJet Printer
Hp designjet 2000cp code 050000 00180516 help us .
05000, on the 2000cp is the printer can not find the mark encoder, inside your printer there is a roller running left to right that the media will sit on,
on the far left side were the roller ends there is a small piece of white plastic that should sit in the vertical position. the sensor on the carriage is not able to find this.
Once you see it, clean with a q-tip, slightly dampened, and also change the lens on the carriage.
Power on the printer when finished and see if it will go to the ready status,
Oct 10, 2009 | HP DesignJet 2000cp InkJet Printer
Carriage belt replacement
Use the carriage replacement procedure in the service manual. Download here: www.lpscomputer.com/ec/manuals.htm
Aug 10, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
I don't know where to buy carriage belt
http://www.computercare.cc/osc/catalog/plotter/size.html
check this link out it sould give u your solution. Please get the size etc correct of the belt and iit should be really easy to find
Jul 05, 2009 | HP Designjet 5500PS 42 Printer Open Box
HP Designjet 5500 - Black not printing
there is a blockage and you need to replace your tube assembly. and maybe your APS.
Jan 27, 2009 | HP Designjet 5500 (42 in.) InkJet Printer
Replacement carriage belt for HP DesignJet 800
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
Nov 19, 2008 | HP DesignJet 500ps (42 in.) InkJet Printer
270 people viewed this question
Seeker5211
Seeker5211
