Question about Sony VAIO Notebook
VAIO Care VPCEl2S1E - Sony VAIO Notebook
I WANT TO INSTAL VAIOCAIR
do you mean vaio care
yes you need to go to vaio support web page you will find vaio care software make sure its compatible with ur model
Thnaks
Jan 24, 2013 | Sony VAIO Computers & Internet
Sony vaio vgn cs 12gh b at start up there is a beep beep sound, pretty loud, and when the password box comes it's automatically filling wwwwwwwwww endlessly. when it's finally open there is this...
Clear the saved passwords
Sony VAIO Care, an application pre-installed on most Sony laptops, is designed to automatically check for computer updates and to assist you with troubleshooting and maintenance. The application is configured to start as soon as the computer powers on. Although Sony VAIO Care is helpful, it is not necessary for it to launch automatically, as having too many programs launch at startup can cause your computer to run slowly. You can disable VAIO Care so it does not run at startup.
Click on "Start," then click "All Programs." Click on the "Accessories" folder. Click on the "System Tools" folder and click "Task Scheduler." Type your Administrator password, if asked for one, and click "Continue." The Task Scheduler window appears. Click on "Task Scheduler Library" in the left pane. Click on "VAIO Care." Click "Disable" under the "Actions" heading on the right side of the window. Close the window. When you next start the computer, VAIO Care will not automatically run
Hope this helps.
Jan 06, 2013 | Computers & Internet
Factory settings sony vgn-n31z/w
Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased.
The computer will restart and the recovery process will begin.
When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition
Turn on or restart your Sony Vaio computer.
Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine.
If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter."
The VAIO Care program will appear on your screen.
Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs
Insert the first recovery disc in your optical drive and restart your Sony Vaio computer.
The total number of recovery discs varies based on your Sony Vaio computer.
The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased. Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete.
The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system
or
Sony Vaio usually installs their system files right on the computer.
If you click on "Start" then "Vaio Central" a window should open up.
Click on the "Support" tab, then "Recovery".
hope this helps
Oct 03, 2012 | Sony Vaio VGN-N31Z/W
Reset to factory without disk
which operating system ?
hope this helps
Sep 30, 2012 | Sony VAIO VGC-JS210J/B 20.1 in. PC Desktop
I want to recover my sony vaio laptop with windows 7 OS, i want to get it back to original state to delete all personal installed programs. pls help
hope this helps
Sep 29, 2012 | Sony Refurbished White 14" Vaio...
Vaic t200 password needed to unlock but none offered. please help
Hi! Welcome to www.fixya.com.
Recover From Within Windows 71Click the "Start" icon in the lower-left corner of the screen and click "All Programs." Click "VAIO Care" then click "VAIO Care" again. The VAIO Care program will open.
2Click "Recovery & restore" on the left side of the VAIO Care window, then click "Recovery." Click "Recovery Computer" on the right side of the program window.
3Click "Yes" to verify that you are aware the computer will be recovered to its original factory settings and that all of your personal files and programs will be erased. The computer will restart and the recovery process will begin. When the process is finished, the computer will restart again and boot up to the Windows 7 setup screen.
Recover Using Recovery Partition1Turn on or restart your Sony Vaio computer.
2Press the "F10" key repeatedly when the Vaio logo appears on the screen during the boot process to be redirected to the Boot Options menu on your machine. If the Boot Options menu does not appear by the time the Windows logo appears on your screen, let the computer finish booting up, then restart the computer and try again.
3Highlight "VAIO Recovery Environment" in your Boot Options menu and press "Enter." The VAIO Care program will appear on your screen. Follow steps 2 and 3 in Section 1 to recover your Sony Vaio computer with Windows 7 to its original factory settings.
Recovery Using Recovery Discs1Insert the first recovery disc in your optical drive and restart your Sony Vaio computer. The total number of recovery discs varies based on your Sony Vaio computer. The Boot Options menu will appear on your screen. Highlight "Start Sony VAIO Care Rescue" using the arrow keys on the keyboard and press "Enter." The "VAIO Care Rescue" program will appear on the screen.
2Click "Tools," then click "Start advanced recovery wizard." In the "Do you need to rescue your data?" window, click "Skip rescue."
3Click "Factory condition," then click "Next." Click "Yes, I'm sure" when asked if you want to proceed with the recovery knowing that all of your personal files and programs will be erased. Click "Start Recovery." Remove and insert the recovery discs as prompted by the computer.
4Remove the final recovery disc and click "Restart" when a message appears on the screen informing you that the recovery is complete. The computer will boot up to the Windows 7 setup screen where you can begin personalizing your operating system.
Read more: How to Recover Factory Settings on Sony Vaio Computer with Windows 7 ' eHow.com http://www.ehow.com/how_7680511_recover-vaio-computer-windows-7.html#ixzz1SY1sA7Sg
Hope this resolution fix the problem on your computer.Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | Computers & Internet
How do i access vaio care?
First you need to make sure VAIO Care is installed in your system.
If you have Vista, go to my programs and look for it.
If you have W7, type Vaio care on the start menu search.
once you find it, open it and follow the screens.
Now if you dont have it, go to the sony esupport website and type your model. download it from there
Mar 01, 2011 | Computers & Internet
How to access recovery partition of Sony Vaio VGN-NW249F laptop?
Hi j5rak,
You can use the VAIO Care Software to access the Recovery Partition within the Operating System.
To open the VAIO Care Software, click Start, All Programs, VAIO Care folder and then click VAIO Care. Then, in the VAIO Care window, in the left pane, click Recovery & Restore . Then you can select the required option in the Recovery & Restore window.
You can also access the Recovery Partition by pressing and holding the F10 Key while restarting the Computer. At the Edit Boot options screen, please press the Enter Key to launch the VAIO Recovery Center.
Good Luck!
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Nov 11, 2010 | Sony VAIO VGNNW240F Notebook
Vaio care, vaio sat survey and vaio luncher have been stopped wor
I had the same problem , i was using a spanish date format.
I changed the date format to an english format (mm/dd/yyyy) and now all vaio programs work ok at start up and afterwards.
Sep 21, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Vaio care stop working
Problem for Sony VAIO CS Series VGN-CS118E/P NoteBook Intel Core 2 Duo... Vaio care stop working
May 01, 2009 | Sony VAIO VGN-CS118E/P NoteBook
Sony VAIO Notebook Logo
32 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
