Question about Emerson Black Microwave Oven
Help, my mircowave
I have a stainless steel red microwave by emerson. I have had it for almost a year and it has went bad. When you start it, it acts as if someone put some aluminum inside of it.
  • 1 more comment
  • Anonymous Nov 11, 2007
    My Emerson microwave oven was operating one second and the next it just blanked out! Nothing. No clock lights, nothing. I checked for burning ordor, or wiring to the plug and wall socket.
  • Anonymous Jan 13, 2008
    microwave will not work at all. Tried different plugs . . nothing. Pressed button to reheat food and it went on for a second then nothing ever since.
  • Jelli May 20, 2008
    Microwave will not heat up
Same thing happened to mine. You need special "security torx" bit to take 2 of the screws that hold the cover on. 20 amp automotive fuse did the trick.
Posted on Mar 23, 2008
I just got one out of the garbage can It was the red one MW8997 It cost a $1.20 to fix, Take the four screws to the out side cover off in the back right corner there's a circuit board with a glass 20amp fuse check it out with a Ohm meter, it looked good but tested bad, Iv been using it for a month now
Posted on Mar 11, 2008
  • Emerson Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and held in place by a plastic rivet.
It can be fragile, and the metal edges behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smmoth and clean.
Then you can apply some high-temperature appliance paint, available from places liek Wal-Mart or Lowe's.
If your waveguide cover is burned, it will need to be replaced.
For more help from Emerson ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
If it's not a problem caused by outside forces, it may be covered under warranty.
Posted on Oct 22, 2007
I need a manual for the MWG9115sl
Many Emerson microwave owner's manuals are available for free download here.
Your specific manual is here.
Emerson support is here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer..
Dec 25, 2012 | Emerson 1100 Watt Black & Stainless Steel...
I have the black/stainless steel m/v MV8999sb. Just today, when I used the any express cooking button, instead of cooking, it is acting like a kitchen timer. It is also flashing to icons on the top; one...
The two icons are normally present for any timed cooking in this microwave. If you are not getting the food to heat (since express cook is at 100% power), the magnetron, thepart that produces the microwaves, may be damaged. If your unit is out of warranty, it may be easier to replace it.
The part itself is fairly cheap: . However, you need to avoid damaging the seals to avoid having the radiation leak. (It makes the microwave inefficient and can be dangerous to people and pets nearby.) Additional parts for microwaves are also available at .
The manual for the MV8999sb is available here: . Click the Get this Manual button. See page 13 of the PDF for the pictures appropriate to the Quick Cook option.
I hope this helps.
Jun 06, 2011 | Emerson Microwave Ovens
Need user manual
Here is a link to an Emerson MW8108bsc (stainless steel version) manual. I would think the operation would be the same. It is from Emerson's website.
Hope this helps
Jan 28, 2011 | Emerson MW8108P Microwave Oven
On the Emerson MW 8992 SB microwave oven how does one change power settings,e.g., from 100% to 50%?
Emerson MW8991SB 0.9Cu.Ft. 900 Watt Touch-Control Microwave Oven, Stainless Steel has the same face as your microwave. I own one of them Look at the bottom three uo to the left it says (POWER) push the Power button it starts at 10 and goes to 1. 10 being the highest and 5 being half power and 1 being the least. then select the amount of time you will cook by punching in the numbers.
Jan 17, 2011 | Emerson Microwave Ovens
Hood range microwave not heating up
We had one that did the same thing. my brother got so mad at it he put a wrench in it and turned it on. It didn't do anything to it. No power surge nothing. It acted as if I put a plate of food. Lighted up turned and even beeped when done. The wrench wasn't even hot. Now I do recommend this myself. But we went and got antoher one.
There is something in there that magnifys the power inside the mircowave and it sounds like its out.
Dec 12, 2008 | Emerson MW8778 Microwave Oven
How can i return a microwave
Did you charge it or write a check? You can get a date of purchase that way. I would check the back of the microwave for the serial/model number and a telephone number or website to contact about the defective product. You can also try the manager of the store where you bought it and see what they can do for you. Hope this helps!
Jun 27, 2008 | Emerson Microwave Ovens
Help, my mircowave
It may have a short, if i were you i wouldn't be using it check to see if your mircowave is on a recall list if its not and your mircowave is under warranty see if you can replace it with a new one
Feb 18, 2008 | Microwave Ovens
Help inside tray will not rotate
check rotated plate and connecting surface ok.
Nov 12, 2007 | Emerson Black Microwave Oven
Emerson Black Microwave Oven Logo
213 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
