Question about Bunn BT10B Coffee Maker
How do I remove the water tray on a Bunn B10B?
I see four deep-set holes into the bottom of the tray, however none of the screwdrivers seem to grip anything and I can't see to the bottom of the holes. How do I remove the water tray?
    Top Expert:
  • Bunn Master
  • 35,672 Answers
You can verify whether there are screws in the holes, by using a bright light for illumination and peering inside. If there are phillips head screws in the holes, you may need to use a metric screwdriver to remove them. The cross slots may require this.
Posted on Nov 27, 2013
3 Suggested Answers
  • 189 Answers
SOURCE: bunn code date 145000 water leak took apart need
If you will call customer service, a seal repair kit can be sent to you which is successful 90-95 percent of the time in fixing the leak problem.
Posted on May 19, 2010
  • 189 Answers
SOURCE: Our Bunn model B10B starting
The water tray is not available but we do have gaskets that usually will fix the leak. If you will call us at 800-352-2866 with the model and date code and we will be happy to assist you.
Posted on Jan 18, 2011
Commercial Bunn CWTF-DV-3T is leaking water from the top right corner of the machine and now at the base behind the bottom burner when you start a pot of coffee
water tank inlet in the top possibly limed up causing pan to overflow. remove top, use screwdriver or deliming spring to poke through the drain nut in the pan. should work fine now
Feb 17, 2014 | Bunn 10 Cup Home Coffee Brewer
Tip
Grip Strip tip for mountain bikes.An easy way to remove mountain-bike handlebar...
Grip Strip tip for mountain bikes.An easy way to remove mountain-bike handlebar grips, even ones seemingly bonded to the bar, is to slide a long thin screwdriver beneath the grip, lift it, drip a little alcohol under the grip and twist. The alcohol will work its way beneath the grip, simplifying removal. To reinstall, drip some alcohol inside the grip and swish it around (hold your finger over the hole in the end if there is one). Then slip on the grip. The alcohol will evaporate quickly, and as soon as that happens, the grip will be secure
on Dec 21, 2010 | Cycling
Hoover carpet cleaner won't dispense solution or water. Everything else works.
1.Remove bottom tank and look for pinched hose. 2.Use small screwdriver or toothpick on small holes which disperse solution-remove rotating brush first. These were problems with my steamvac (f5861-900 model).
Mar 16, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
What size allen key is used to take the four screws out of the bottom of the unit? is it metric?
The screws in the bottom are Torx T10, which is a lot smaller than the Torx bits in a typical screwdriver set. The other problem is that since they are in deep holes you need a long and skinny (about 1 1/2") bit to reach them. Thus you need a dedicated T10 screwdriver, not an interchangable bit in a holder. You can get a T10 screwdriver at sears for about $5. You can also get the Kobalt folding Torx set (with Torx sizes from 9 to 40) for about $10 at Lowes.
Dec 28, 2010 | Cuisinart DCC-1200 Coffee Maker
Our Bunn model B10B starting leaking done the stainless steel cylinder. I took it apart. The part of the top tray between to two rubber washers had disintegrated. How do I get a new black top water...
Sep 18, 2010 | Bunn BT10B Coffee Maker
Had about a week. if i fill with 50 ounces of
Try taking the filter out, and turn the sprayhead off the unit. Put the basket back on, and try pouring clear water through the unit. If the water runs through fine, you either have a plugged sprayhead or are using too finely ground coffee. Look at the holes in the sprayhead, and make sure that none of the holes are plugged. If the basket still overflows, try using a drill bit to make the hole in the funnel a little larger. Good luck.
Mar 06, 2010 | Bunn BT10B Coffee Maker
Bunn GR10 has a hole in the panal where the water runs into the
The only place I know of that you might be able to find a replacement tray for this style of brewer is from your local Bunn repair shop IF they have a used unit laying around that died from something else. Bunn will not even send out these parts to their repair centers. Good luck!!
Feb 04, 2009 | Bunn GR10 Coffee Maker
Water leaks out of holes up under resevoir.
Use a Torx T-9 tamper resistant screwdriver to remove the screws on the bottom of the coffee maker.
Your plastic tube has probably come loose or is leaking. Carefully re seat the plastic tube over the metal tube using the metal spring compression clamp.
Jan 09, 2009 | Bunn NHB Coffee Maker
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
Bunn Coffee Maker Leaks out the bottom
I have an older BUNN B10 pour-o-matic that I thought was leaking from the bottom. Upon close inspection, I found that it was leaking from the worn out washers located on the top of the tank, allowing water to run down the sides of the stainless steel tank. There's a great fix offered on Fixya.com that suggests going to a hardware store and buying a Gardner Bender GHG-1575 rubber grommet with a 3/4" hole and install it into the large hole in the basin. Then place a metal washer on top of the grommet and snug it up with the threaded fitting. Many folks say it's a great fix. I went a different route. I called BUNN customer service and spoke to a very nice woman who understood my needs and sent out a free repair kit that contained a new fitting, washer, and seal. I received it in a few days and it's working great. Beats going out and buying parts for a work around repair. BTW, the repair kit is called "Universal Retail Seal Replacement Kit #37091.0000"
Sep 22, 2007 | Wega Mininova EPU Espresso Machine
Bunn BT10B Coffee Maker Logo
32 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
