Question about Bunn BT10B Coffee Maker
I have Bunn B10B that is leaking from the water tray. I understand there is a gaket thatw will fix ts, but I can't figure out how to remove the water tray. There are four deep-set holes into the tr
How do I remove the water tray? There are four deep-set holes in the bottom of the water tray assembly. I assume there are screws set into those holes, bu I can't grip them with any screwdriver, nor can I see to the bottom of the holes. Please advise.
4 Suggested Answers
  • 189 Answers
SOURCE: bunn code date 145000 water leak took apart need
If you will call customer service, a seal repair kit can be sent to you which is successful 90-95 percent of the time in fixing the leak problem.
Posted on May 19, 2010
  • 189 Answers
SOURCE: Our Bunn model B10B starting
The water tray is not available but we do have gaskets that usually will fix the leak. If you will call us at 800-352-2866 with the model and date code and we will be happy to assist you.
Posted on Jan 18, 2011
  • 36401 Answers
SOURCE: How do I remove the water tray on a Bunn B10B?
You can verify whether there are screws in the holes, by using a bright light for illumination and peering inside. If there are phillips head screws in the holes, you may need to use a metric screwdriver to remove them. The cross slots may require this.
Posted on Nov 27, 2013
Nov 27, 2013 | Bunn BT10B Coffee Maker
Leaks water
the tray you pour the water into sits directly on the tank that heats the water with a gasket between tray and tank, this gasket has worn away, Bunn no longer sends replacement gasket, I made one myself
Feb 25, 2013 | Bunn 10 Cup Home Coffee Brewer
Our Bunn model B10B starting leaking done the stainless steel cylinder. I took it apart. The part of the top tray between to two rubber washers had disintegrated. How do I get a new black top water...
Sep 18, 2010 | Bunn BT10B Coffee Maker
Bunn 10 cup home coffee brewer is leaking from the bottom area. Any ideas on how to repair this?
These models have a plastic pour-in tray just under the top lid. The plastic on these trays gets brittle over time with the heating and cooling, and they crack where they mount to the tank. The only real way to repair this is to replace the pour-in tray, but these are not sold anywhere that I have found. You might be able to find a used one at a Bunn dealer in your area.
I have seen some people do a temporary repair by putting a washer under the mounting bolt and sealing it with silicone, but this is a temp. fix at best. By the way, the reason that the water appears to be coming from the bottom of the machine is that there is no other place for the water to come out after it leaks from the top.
Apr 22, 2010 | Bunn 10 Cup Home Coffee Brewer
Bunn code date 145000 water leak took apart need
Mar 25, 2010 | Bunn 10 Cup Home Coffee Brewer
Unit leaks water from bottom bunn pouromatic
What model of Bunn is this? If it is a bx-b or any of the other home models, what has happened is that the plastic pour-in tray has become brittle and cracked where it mounts onto the tank. The only repair for this is to replace the tray with one from another brewer (possibly your local bunn Dealer has an old brewer lying around). If it is a commercial brewer (VPR, VPS, Ect) there will be a sael leaking on the top of the tank.
Nov 26, 2009 | Bunn Coffee Makers & Espresso Machines
Leaking pour basin
Your only hope of getting a new tray for these would be if your local Bunn repair shop has some hanging around that broke down for another reason. This is a very common problem with those models. You can find a list of Bunn repair depots at www.bunn.com Good luck!
Jan 21, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn (Pour Omatic) coffee maker has been leaking water - what would couse it to leak? Thank you
When a machine leaks, it is generally an indication of a bad seal or gasket. If you will call Customer Service at 800-352-2866 with the model and date code we will be happy to help you resolve your issue.
Oct 28, 2008 | Bunn NHB Coffee Maker
Bunn Coffee maker
your problem is caused by the pour-in tray leaking where it mounts to the tank. There should be 2 screws under the pour-in lid, and a third toward the rear of the brewer. if you take them out & lift up carefully, you can see the pour-in tray. in the bottom of the tray, there is a bolt that mounts the tray to the tank. If you remove that, you can lift the pour-in tray out. Be careful, as these trays get brittle over time, and are prone to cracking.
Sep 05, 2008 | Bunn NHB Coffee Maker
Bunn Coffee Maker Leaks out the bottom
I have an older BUNN B10 pour-o-matic that I thought was leaking from the bottom. Upon close inspection, I found that it was leaking from the worn out washers located on the top of the tank, allowing water to run down the sides of the stainless steel tank. There's a great fix offered on Fixya.com that suggests going to a hardware store and buying a Gardner Bender GHG-1575 rubber grommet with a 3/4" hole and install it into the large hole in the basin. Then place a metal washer on top of the grommet and snug it up with the threaded fitting. Many folks say it's a great fix. I went a different route. I called BUNN customer service and spoke to a very nice woman who understood my needs and sent out a free repair kit that contained a new fitting, washer, and seal. I received it in a few days and it's working great. Beats going out and buying parts for a work around repair. BTW, the repair kit is called "Universal Retail Seal Replacement Kit #37091.0000"
Sep 22, 2007 | Wega Mininova EPU Espresso Machine
Bunn BT10B Coffee Maker Logo
44 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
