Question about Plumbing
Problems in ww1 trenches
Need ideas
Can you mix bleach with vinegar to kill mold?
Don't know you can try. It might work.
Good luck
Mai
Feb 07, 2017 | Washing Machines
Can you please tell me about the Battlefield 1 game's compatibility with different operating systems?
BF1 Hack is one of the best game that makes you feel what soldiers of first world war do. As the game is on the theme of WW1 and it also uses many of the vehicles and hacks that are used at the time of WW1. You can play this game in many platforms as it is compatible with - Windows 7, Windows 8, Windows 10 and it is compatible with 64 bits systems only.
Nov 23, 2016 | The Video Game Consoles & Games
What is the volume of 13' x 3" into gallons
13' x 3" is a measure of area. Gallon is a unit of volume. There is no direct conversion.
Let's say you have a skinny trench 13 feet long by 3 inches wide. How many gallons of water is in the trench? That obviously depends on how deep the trench is.
Apr 24, 2014 | Office Equipment & Supplies
I need Dell OptiPlex GX270 PC Desktop ethernet drivers
If you have lost/misplaced the installation disk, you can download the drivers from:
http://support.dell.com/support/downloads/devices.aspx?c=us&l=en&s=gen&osl=en&SystemID=PLX_PNT_CEL_GX270&os=WW1
Hope this solves your problem. Thanks for using FixYa.
Mar 08, 2011 | Dell OptiPlex GX270 PC Desktop
I have a trench 1475' long, with three rows of 3'' pipe.
If the pipes are 3" outside diameter, the displacement is 24.15 cubic yards, however standard 3" pipe is 3.5" diameter, which would displace 32.85 cubic yards. 505.32 cubic yards is correct for the total trench volume.
Mar 23, 2010 | Plumbing
There is a trench/drain on the back wall behind
If you can view to rear of the unit wnd remove the bottom panel, there should be a hose coming from the drain to a pan of some type. If it has clamps on both ends remove the tube, place a vessel under the top tube attach point of trench drain and test the trench drain, if water is flowing freely from the drain to the vessel then clean out the tubing and replace.
Jul 16, 2009 | Refrigerators
Breakers advice
When trenching, the breaker is expected to fracture a solid mass of rock into manageable pieces. The size of the material could be 100's of cu.yds, and the energy will be quickly absorbed. This is why it is recommended to work from a bench so the rock has somewhere to break out. We recommend when trenching in limestone or medium hard rock, to use a 3,000 - 5,000-ft. lb. breaker. When working in hard material we recommend a 7,500 - 10,000-ft.lb. breaker, and if high production is critical, a 13,500-ft.lb. breaker would be beneficial.
Aug 27, 2008 | Belle Group BHB30 - for 5 gallon Hydraulic...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
