Question about Refrigerators
Sears Galaxy side by side refrigerator lights interior lights suddenly went dim and now the freezer side is making a low, slow sound like something is trying to work. Ice dispenser works but makes odd sound. HELP!!!! It's tge day before Thanksgiving!
    Genius:
  • 1,198 Answers
Your outlet may need replacing. I have been replacing all the outlets here, the installer did not attach the power wires to the screw on the outlet, he just jammed them into a hole in it, the lazy way.
Plug something into the same outlet, if it runs slow or dim, that's your problem.
Turn off the breaker before you mess with an outlet.
Posted on Nov 28, 2013
  • Shan Garcia
    Shan Garcia Nov 28, 2013
    Turns out it's likely a low voltage thing coming from the power lines. It's an old hous. We have dimming lights every time the neighbor turns on a major appliance and likely power surges as well. I'm going to have them check everything before an electrician is called out. The fridge went back to normal operation within a half hour and after several unplugs and plugins.
  • mike kirschbaum
    mike kirschbaum Nov 28, 2013
    I would get a power interupting surge protector. They are not cheap, but will protect your fridge. If the powe gets too low, it will turn off the power to the fridge until proper power comes back. Bad power can burn out appliances.
4 Suggested Answers
  • 23 Answers
SOURCE: ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Posted on Dec 08, 2007
hapndnvegas
  • 35 Answers
SOURCE: GE Ice dispencer not working properly
for a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Posted on Mar 27, 2008
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
1999 chevy malibu 6 cyl. Was driving and all of a sudden rmps went low car would not go even with foot to floor. Once I let the foot off car would go. When rmps are low all interior lights on dash...
It sounds like the alternator isn't working. If the battery voltage gets below 10.8volts it starts to shut systems down, like engine computer, fuel injectors, electrical loads(lights) etc. Get your alternator tested or replaced. Also make sure you battrey connections are clean and tight. If they are loose the alternator can't replenish the battery power due to excessive resistence in the cables.
Jan 27, 2011 | Chevrolet Malibu Cars & Trucks
My freezer is not working properly with clicking sound.
The clicking sound is probably the compressor relay trying to start the compressor. When the lights dim, the compressor is trying to start and hence, pulling power from the rest of the unit. If the compressor has a start capacitor, that could possibly be the problem. If not, the compressor itself should be replaced.
Mar 26, 2010 | Maytag MSD2454G Side by Side Refrigerator
Need to disassemble a Sears Kenmore 106.57372700
Sounds like the IM heater stuck on that's the only thing that would have melted liner. Check the optics open the freezer door and push the flapper on the right side back and look for a green light if it's on solid optics are ok if there is no light or flashing replace the emitter and receiver
Feb 16, 2010 | Whirlpool GS2SHAXM Side by Side...
I have a GE profile side by side model PSS26SGRCSS. Lately the water and ice dispenser have worked only intermittently with a dimming of the lights. Tonight it stopped working and the temperature display...
Something has malfunctioned on *********** control board part number WR55X10942 This board controls most functions of the refrigerator. It would be simple to say change the board but this is the first time I have seen one affect so many different controls that I recommend that a service technician come out and make sure that something other that that board is not affecting the other controls on your refrigerator. Please let me know what the technician finds, Thanks, Sea Breeze
Sep 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Lighting in freezer
there are two lights, one on the bottom of the freezer behind the second drawer up, under a plastic difuser
Jan 07, 2009 | Frigidaire FRS266ZDSB Side by Side...
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Noise from Deodorizer
Sounds like the circ. fan may be hitting something or has a blade broken off. The refer gets cool air from the freezer section to cool it so the fan aids in the circulation along with vents/dampers, etc. to move air into the refer compartment. If that fan is broken off the motor shaft or something then the motor can run but no air will move. See if you can feel air moving out of the vents, it will be a little bit of "blowing" not a huge wind. A wet hand can help feel for wind. I believe the deodor light may indicate a change is needed (but check the owners manual for actual meaning). If there is no air flow open the freezer section and see if the air flow is noticed then... if a air channel if frozen and can't draw air from the proper area, opening the freezer door will give it outside air and you may feel flow then, that would tell you of a frozen air channel issue.
Oct 16, 2006 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
