Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Making loud noise
I have a Bissell Power Force Bagless Turbo. It was shaking and burning rubber, so I bought a new belt. I installed the belt, but the shaking and horrible sound persists. Now what???
    Problem Solver:
  • 31 Answers
Check the bearing on brush
Posted on Nov 27, 2013
reddevil6
  • 1673 Answers
SOURCE: bissell power force
turn vac over, take of the access plate covering the brush roll, may be 2 to 4 screw. Then you can get to the brush roll and belt. It uses a Bissell Style 7 belt.
Posted on Jan 09, 2008
  • 389 Answers
SOURCE: bissell lift off, brush won't move smell burning rubber belt fine
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Posted on Mar 08, 2009
SOURCE: brush will not turn
Possible Solution: I had the same problem with my Powerforce vacuum. Please take note that I AM NOT a vacuum cleaner repairman, nor have I played one on TV. Try taking your beater bar out, and if it looks similar to the one pictured (Model#203-1195), get a cresent wrench. Look at the end of the beater bar one will be squared on the sides to hold the shaft inside statonary. Take the wrench and adjust it to fit the nub on that end. Grab the bar in the center, and turn the end with the wrench. Mine popped and came loose, then it could be turned by hand. A little light oil allowed to run into the end cap, turn it up and spin it a few times to let the oil work down the inside and put it back on. Mine works fine for now. Good Luck!!
Posted on Mar 16, 2009
  • 16 Answers
SOURCE: My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
Posted on Nov 03, 2009
VacuumRepair
  • 438 Answers
SOURCE: Belt keeps burning and breaking
Hello There,
It sounds like you need to replace the roller brush. If your Bissell is breaking belts that fast, then that can only really mean one of two things. The first being that the belts are not being properly installed, and the roller brush is pinching the belt which causes the belt to break, but after 3 belts I doubt this to be the case.
Probably the more likely problem is that the brush roller's bearing have seized up. You may test this by removing the roller brush from the vacuum, and holding it with on your two pointer fingers holding the outside bearing caps of the brush, making sure not to touch the actual part that spins. Now try to spin the brush while holding the bearing caps with your pointer fingers. The brush should spin freely, and should revolve around 5-6 times with each spin. If the brush doesn't spin easily, then this is going to put a lot more stress on the belt.
You may try to remove the bearing caps on the ends by twisting them off, and visually inspect each side to make sure there is no hair or thread that's lodged inside the bearing cap. This will make the brush hard to spin, and can cause you to burn belts quickly like you have been. You may find the bearing caps will not come off. This indicates that your brush roll has worn out the bearings completely, and the bearing caps have melted to the bearings due to extreme heat. You will then need to replace the roller brush if this is the case, and it maybe the best solution for you if you have burned through 3 belts so quickly.
The roller brush for your Bissell (I'm assuming this is yours as this is where the repair was posted on Fixya) 6594 PowerForce upright uses Bissell roller brush part number; 203-1195. Here's a link if you need to purchase one;
http://www.govacuum.com/biclandpobar.html
I have uploaded the parts schematic and owners manual to the main Fixya page for your model as well. Sometimes it can take 24 hours for Fixya to publish this data, but please visit the link to these documents in 24 hours or less;
http://www.fixya.com/support/p49887-bissell_6594_powerforce_bagless_upright#manuals.
If your roller brush is good, then examine where the brush rests inside of the vacuum cleaner, this is called the agitator housing. Look at the sides of the agitator housing where the bearing caps rest. Do you see any visible damage on either side? Sometimes the brush can get so hot, it may melt the agitator housing on the sides where the brush rests, this will also cause the belts to burn very quickly.
I hope that this information is helpful to you. If none of these suggestions fixed your vacuum, please just add a comment, or request a clarification request here on Fixya, and I'll be happy to respond. If this was helpful, please be sure to rate the repair by clicking on the 4 thumbs up icons in the upper right hand corner.
Thank you,
Chris J.
GoVacuum
Posted on Mar 23, 2010
Bissell ProHeat Turbo Deep Cleaner Upright Steam is make a loud noise please help
Check the underside where the drive belt comes off the electric motor. Maybe something got wound up on the motor pulley if you are lucky.
If you aren't lucky it could be the bearing is out and the motor is just screaming and overheating...soon to seize up
If you do need a new motor, there are some repair videos on YouTube:
https://www.youtube.com/results?search_query=why+is+my+Bissell+ProHeat+carpet+cleaner+making+very+loud+noise
Nov 20, 2015 | Bissell Vacuums
Bissell 6591 operating twice as loud as before.
Hey Mike! Excessive noise can be contributed to dirty filters or clogs. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1421&cid=ccsocial
Feb 03, 2013 | Bissell 6591 Power Trak Revolution Bagless...
Bissell lift off bagless making high pitched noise, fan seems to run for 30 seconds after shutting off, and a burning rubber smell, is it the belt, and how easy are they to change
The burning rubber smell is usually the belt. Be careful not to use it on your carpet as the rubber belt can get hot and liquify and really mess up your carpet (if you have one). Here's a link to some instructions for replacing the belt.
http://www.ehow.com/how_4550054_replace-drive-belt-bissell-powerforce.html
Mar 15, 2010 | Vacuums
Vacuum sounds like an airplane after 1 year of use.
the motor bearings are starting to fail most likely. You can diagnose the source of the noise by removing the brushroll and belt, could possibly be the brushroll bearings but if you still get the noise when the belt is off its the motor.
Jan 07, 2010 | Bissell 6594 PowerForce Bagless Upright...
I have a bissell powerforce bagless vacuum. My
Its probably is the roller brush causing the noise.
Nov 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
My vacuum makes a really loud noise when I turn it on. It was working and now it smells like something is burning. I check the belt- it looks ok.
The belt may look okay but it still can be stretched or worn and can be slipping on the motor shaft and thats why you have the burning smell. I would try changing the belt. Here is a link to the manual and a link to the belt you need:
Bissell Momentum User Guide (PDF)
Bissell Momentum Replacement Belts
Oct 31, 2009 | Bissell Vacuum - Momentum Cyclonic 1 ea...
My Bissell Cleanview Bagless vacuum makes loud grinding noise.
the ends of the roller have something wrapped around them.see if you can pull the ends off so you clean the caps and bearings
Apr 09, 2009 | Kenmore Progressive Bagless Upright with...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
150 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
