Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Tablet not dissolving, dishes not clean
Soap Tablet not dissolving and looks like dishes are not clean. I call tech before and he said that the grey plunger on bottom right corner was pushed down and this caused the problem. I can lift the grey plunger out so I don't thing that it is causing the problem. Help, I don't want to call for service help again. Trina
  • Trina795 May 08, 2009
    Thank you so much!
  • 10,865 Answers
Hi Trina. I wish I was nearby as I would come over and take care of this problem for you.
There are two possible reasons for the situation as you describe it: 1. Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
2. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
If you are mechanically inclined you can repair either of these but if you are not you will have to hire it done. Now that you know it is one of two problems you can tell the repairman ahead of time and get a price on the repair. Then shop around for the best price.
Posted on May 08, 2009
Whirlpool wdf310paa not cleaning dishes
Check water supply. Saddle valve failure can restrict water flow. DW
Apr 12, 2014 | Whirlpool Dishwashers
Tablet not desolving after quick wash cycle
Find out whether your quick cycle is a wash cycle or a rinse only. If it is a wash it's obviously too short, and the tablet is not dissolving. You do not want undissolved tablets because they will contaminate your rinse water and u end up with soap on the dishes. You can switch to powder if a tablet isn't going to dissolve quick enough on your quick cycle.
Jun 03, 2011 | Bosch Dishwashers
My dish washer soap does not dissolve, whether or not I put the tablet or the pillow into the soap dispenser. Is it the soap dispenser door? Would hard water buildup create low water pressure so the soap...
The most likely causes are the you are using a tablet in a gel coating but putting the tablets into the dispenser drawer when the dispencer drawer is damp, thus causing the tablet to stick inside the housing; or, if the dispenser drawer is releasing the tablet into the bottom of the cabinet then I would say you have a problem with your water heater. In which case you would need an enginner to come and replace the heater.
Hope this is of help
Jan 25, 2011 | Maytag MDB7100AWB Dishwasher
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
The door for the soap has a small crack/hole
you can patch the crack/hole with a one minute marine epoxy. It works great. Regarding the fact that the tablet won't dissolve, you may wish to try a different dishwasher tablet or powder. You may also have another problem with your machine. Are your dishes coming out clean?
May 16, 2009 | Dishwashers
I have a Chef Classic dishwasher - not washing properly
The caddy for cutlery on this model is in front of the compartment where you put the tablets. What'll sometimes happen, is a spatula or wooden spoon or something in the caddy will hold the tablet compartment lid shut - it'll stop them coming out properly.
After a while the water movement will move the obstruction and the tablet will come out, but it'll only be dissolved for a bit of the wash and the dishes won't be cleaned properly.
Dec 18, 2007 | Magic Chef CDB6100 Built-in Dishwasher
Soap does not seem to dissolve or clean
Probably a sticky dispenser door. Run for a few times with the dispenser open and put a tablet in the cultery basket
Nov 23, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
Nov 16, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
322 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
