Question about Car Audio & Video
Obd scanner say's bank 1&2 running lean, also tells me that it is the oxegen sensors. on a mecury there are 4 sensors,which 2 would be most likely? if i disconnect the battery to reset the comupter it takes about 48 miles before the check engine lite comes back on.
  • 34 Answers
Disconnect each sensor individually and whatch the check engine light to see if it comes on usually when the check enging light comes on after driving for a certain amount of time or miles its not an o2 sensor its more that likely a valve somewhere like EGR valve or PCV valve....also check all your vaccum lines before attempting any repairs for you may be throwing money out the window if one of your vaccum lines is cracked. happened with my mustang i replaced my egr valve when all i neede where new vaccum lines. because the egr valve lines where cracked and the egr valve diaphram wasnt getting enough vac pressure.
Posted on May 08, 2009
Mercury sable 2002 fault codes p0132,p1131,p1132
PO132 oxygen sensor high voltage bank 1 sensor 1
P1131 & P1132 lack of upstream heated oxygen sensor switch bank 1
Feb 23, 2015 | Mercury Cars & Trucks
2005 Mazda Tribute P0172 & P2270
Hi Paul, Have you had a fault code relating to the knock sensor? That sensor controls ignition timing which can have a relationship to the fault codes you report? Regards John
Apr 06, 2013 | 2005 Mazda Tribute
I HAVE A P0300 OBD CODE I DID A COMPRESSION TEST TO ENGINE AND IT PASS THE TEST,I DID CHECK EGR VALVE,CHANGE SPARK PLUGS,IGNITION WIRES, CAP AND ROTOR, I DID CHECK TPS SENSOR MAF SENSOR,FUEL PRESSURE,AND...
p 0300 code is for random misfires
random misfires are more from dirty /faulty injectors or low fuel pressure than anything else
have a pressure test done to check pressure regulator , filter and pump operation
use a can of quality injector cleaner or remove and clean the injectors
Apr 06, 2017 | 1997 Nissan Pathfinder
Engine codes displayed on OBD tool
You might want to start with spark plugs. I'm not sure if that year has coil on plug ignition, but if it doesn't, spark plug wires are probably in order as well. Some of the O2 sensor faults could be caused by the poor ignition your mis-fires are causing. Sensor 1 is closest to the engine, sensor 2 is further away, on the other side of the Catalytic converter.
May 09, 2017 | BMW 325Ci Cars & Trucks
Where is a HO2S21 sensor located on a 99 mecury cougar?
Its saying bank 2 sensor 1 Bank 1 is the same side of the motor as the number one cylinder. Bank 2 is the other side of the engine. Sensor 1 is always before tha catalytic converter. Sensor 2 is always after the catalytic converter. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 05, 2012 | Cars & Trucks
Check engine light came on found the code and a lean condition was found by the computer
either your bank 1 sensor 1 or 2 or bank 2 sensor 1 or 2 oxegen sensors need replaced
if this helps please give me a good rating
May 06, 2011 | 2005 Toyota Corolla
Ù?دÙ? Ù?Ø´Ù?Ù?Ø© فÙ? سÙ?ارتÙ? اÙ?تÙ?ا
Generic OBD II Diagnostic Trouble Codes
DTC CODES P0200 to P0299
P0200....Injector Circuit
P0201....Injector Circuit - Cylinder 1
P0202....Injector Circuit - Cylinder 2
P0203....Injector Circuit - Cylinder 3
P0204....Injector Circuit - Cylinder 4
P0205....Injector Circuit - Cylinder 5
P0206....Injector Circuit - Cylinder 6
P0207....Injector Circuit - Cylinder 7
P0208....Injector Circuit - Cylinder 8
P0209....Injector Circuit - Cylinder 9
P0210....Injector Circuit - Cylinder 1
P0211....Injector Circuit - Cylinder 11
P0212....Injector Circuit - Cylinder 12
P0213....Cold Start Injector 1
P0214....Cold Start Injector 2
P0215....Engine Shutoff Solenoid
P0216....Injector/Injection Timing Control Circuit
P0217....Engine Coolant Over Temperature Condition
P0218....Transmission Fluid Over Temperature Condition
P0219....Engine Over Speed Condition
P0220....Throttle/Pedal Position Sensor/Switch 'B' Circuit
P0157....O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158....O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159....O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160....O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161....O2 Sensor Heater Circuit (Bank 2 Sensor 2)
P0162....O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163....O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164....O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165....O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166....O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167....O2 Sensor Heater Circuit (Bank 2 Sensor 3)
P0168....Fuel Temperature Too High
P0169....Incorrect Fuel Composition
P0170....Fuel Trim (Bank 1)
P0171....System too Lean (Bank 1)
P0172....System too Rich (Bank 1)
P0173....Fuel Trim Malfunction (Bank 2)
P0174....System too Lean (Bank 2)
P0175....System too Rich (Bank 2)
P0176....Fuel Composition Sensor Circuit
P0177....Fuel Composition Sensor Circuit Range/Performance
Nov 29, 2010 | 2005 Nissan Altima
Where is the oxegen sensor located on a 2000 chrysler town and country 3.8 liter. does the oxegen sensor have a fuse
the oxygen sensor is located in the exhuast pipe,there could be more than one sensor, maybe 4 sensors on a 6 cylinder car and 2 sensors on a 4 cylinder car,so youre gonna have to know which one is bad,if the check engine light is on it will tell you which position sensor is bad like bank 1 sensor 2 something like that,also there is NO fuse for the o2 sensors
Oct 19, 2009 | 2000 Chrysler Town & Country
Code po171 and po174. fuel bank 1 & 2 lean. what can i do about it
From Twitter by @carpartslocator.
@car_problems oxegen sensor oar the airflowmeter.but i do not know what kind of car you have i am gessing ford....??
Good luck.
Jul 19, 2009 | 2001 Ford Explorer Sport
Car Audio & Video Logo
56 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
