Question about Dishwashers
It seems to turn on but no water flows in I can here the motor running but no water flows the water has not been shut off
  • 10,865 Answers
There are two possible reasons for the situation as you describe it: 1. Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
2. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
If you are mechanically inclined you can repair either of these but if you are not you will have to hire it done. Now that you know it is one of two problems you can tell the repairman ahead of time and get a price on the repair. Then shop around for the best price.
Posted on May 08, 2009
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
Maytag neptune MAH5500BWQ hot water fill runs slow
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Apr 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
My 2 year old frigidaire dishwasher is not filling up with water, goes through cycle but no water is coming out, valve is open all the way?
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Click on : Inlet valve
Jan 25, 2013 | Dishwashers
New installation. water flows correctly with main pump on and working. when booster turned on, motor runs seemingly normally but water flow to sweep is blocked entirely.
Inside the wall you have a screen that may be plugged. remove the hose from the wall and the fitting will have the screen inside it.
Jun 24, 2010 | Hayward .75 HP Booster Pump
Pump worked yesterday but would not shut off. I left pressure in system over night, today pressure gone, when I turn pump on, the motor runs, but no pressure or water pumped.
1.Turn off the power going to the pump.
2.Drain all the water inside the pressure tank.
3.Open the priming port plug of the pump, and fill it
full with water.
4. Put the priming port plug back in place. Close the
flow control valve and start the pump.
5. Slowly open the flow control valve to 1/8 to 1/4
open and see the flow stabilize at 20 psi of the
pressure gauge.
Hope this will help.
Nov 20, 2009 | Plumbing
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Water starts but never turns off
If water is filling the tub, then the problem is with the pressure switch or the control board.
A siphoning problem through the drain hose could also cause this problem.
Make sure that your drain hose is properly installed .
Jan 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
Dec 21, 2007 | Admiral AW22 Top Load Washer
Dishwashers Logo
Top Dishwashers Experts
