Question about Blackburn Flea Rear Flasher Bicycle Taillight
My Flea Taillight won't charge, I'm using a brand new "AA" battery, (hooked up - red to + and black wire to - ) I've reset the "light from demo mode (holding down the button for 20" sec.) and the light isn't coming on while charging?
  • 3 Answers
Try cleaning the contacts with a cotton swab and som isopropyl alcohol.
Let those dry.
Use a paper clip, or other small pointy object to clear the area around the contact points on the light so the recharger can fully "snap" into place.
Attach a battery you know has a good charge.
Turn on the light.
Did the light turn on?
If so, great, turn it off, and if it is blinking, let it recharge.
If it didn't turn on, isn't blinking and won't hold a charge after this process, return it to Blackburn and enjoy the benefits of your lifetime warranty.
Posted on Oct 16, 2009
What battery to charge it
You want to use a 1.5 volt battery like: AAA, AA, C, or D.
Mar 16, 2014 | Blackburn Flea Rear Flasher Bicycle...
Are battery replaceble
I was able to replace the original NiCad AA batteries with a NMiH 2.4V 1500mAH (3.6 Wh) cordless phone battery Uniden BT-1015. Take out the three screws holding the back on. loosen the battery clamp, slide out the old battery and unplug it, cut off the plug on the new battery, strip each wire about 1/4 inch, push the new wires into the old wire plugs maintaining color, black to black, red to red, fasten new battery under battery clamp, adjust new battery so back of case goes on, fasten back on with original screws, charge new battery with original battery charger over night. I got my new Jensen brand battery at Meijers.
Apr 19, 2013 | Hamilton Beach 76501G Walk n Cut Can...
Switronix Tl-50 won't turn on
I too have had a problem with mine no longer charging. I talked to the manufacture. Since the cord light is on however my torchlights charging light is not on they said could be the batt or could be a bad wire in the charger. I've been debating whether to send it in for fix or buy a new batt to try first. For yours I would send in for repair. Unfortunately these lights only come with a 1 yr manufacturing warranty so if you've had it over a yr you will end up paying 60-130 was the price range I was quoted depending on the problem.
Mar 03, 2013 | Switronix TorchLED TL-50 Video Light - 75...
I need to know how to wire the batteries together on my shoprider jimmie chair so they will charge
If the charger is 24 volts and you have 2 12 volt batteries they have to equal 24 volts , so wire the batteries terminals red to black and connect the charger to the other terminals red to red and black to black.
Feb 10, 2012 | Shoprider Jimmie Power Wheelchair
After charging the Blackburn Rear Light, it won't turn off. Any suggestions on how to get it to turn off.
Your Flea iscontinuing to flash because it acquired extra energy during the charge. Once the extra energy has been burned it will shut off. To help preventthis try to charge the Flea for no longer than an hour to an hour and a half,and don't charge the Flea after every use.
Aug 02, 2010 | Blackburn Flea Rear Flasher Bicycle...
How do I insert the battery into the Blackburn flea?
It's a rechargable light, with a built in battery and no supposed user replacable battery. You need the USB dock to charge it either through your computer or using the optional Blackburn solar panel.
Jan 16, 2010 | Blackburn Flea Front HL Bicycle Headlight...
When i turn on my camera it will not extend or let me set the men
Check batery type suitble for your camera, also ensure correctly installed(+ -) Check contacts are clean
Sep 24, 2009 | Fuji FinePix A360 Digital Camera
I cannot get Blackburn flea to take a charge. It only the 2nd time I am recharging the rear flea. Its a brand new battery.
It might be stuck in 'display mode' (described on the package). Try holding down the button for twenty seconds until you see the signal. Then try turning it on normally again.
Aug 29, 2009 | Blackburn Flea Rear Flasher Bicycle...
Blackburn Flea Rear Flasher Bicycle Taillight Logo
2,092 people viewed this question
Top Blackburn Cycling Experts
John Egan
John Egan
Donald Ayers-Marsh
Are you a Blackburn Cycling Expert? Answer questions, earn points and help others
