Question about Olympus FE-25 Digital Camera
I have olympus fe-25 camera with broken lens, where can i find the replacement
The camera was working fine but being a engineering student out of curiosity i disassembled it and by mistake broke the lens ribbon cable. can someone please tell me where can i get the replacement lense.
  • 383 Answers
SOURCE: Idiot dropped my Olympus FE-220. Lens broke!
take it to a repairman .... he will be able to fix ....
Posted on Dec 07, 2008
  • 919 Answers
SOURCE: Olympus Camera FE-170 Problem in recording Voice
Recording moving images. Sound is not recorded
This is straight from your camera's user manual.
The camera does not have any way to provide sound with the movie clips. This is how the camera was designed by the manufacturer.
Posted on Jan 08, 2009
  • 919 Answers
SOURCE: i droped olympus fe360 camera and the lense will not go back in i can hear it but no action !
The problem you are describing is a problem with something in the lens assembly. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $68.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Apr 14, 2009
  • 318 Answers
SOURCE: Olympus FE 370 Broken Screen
You need to remove the back of the camera by removing the screws that goaround the perimeter. Then gently pry open the back. Then gently pry the screen edge that is closest to the out side and work around till it loosens. Then you must peel back a clamp tiny bar that holds the wire cable on to release it. reverse to install.
Posted on Dec 18, 2009
  • 11967 Answers
SOURCE: Olympus fe-4000 lense won't open
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 22, 2010
My cameras lens are broken.what is the price of the original lens
You can get a replacement one from Ebay for $30.
http://cgi.ebay.com/Olympus-FE-280-Digital-Camera-LENS-ZOOM-ASSEMBLY-/220693961161?pt=Digital_Camera_Accessories&hash=item33626299c9
Jan 05, 2011 | Olympus FE-280 Digital Camera
I m using olympus fe 25, after updating firmware through olympus master 2 , firmware version 1.1 , when i switch on camera the lence are coming out , but there is no display on lcd , this may be the...
I don't know what the firmware was supposed to correct but If you didn't follow the download and installation directions perfectly, you could have problems.
Oct 12, 2010 | Olympus FE-25 Digital Camera
Focus problem olympus fe 34o
Not focusing at every distance - close to far ?? That seems like a lens problem to me and how the lens is focused, once its fully extended, varies between camera brands. .
Have you dropped this camera or knocked the lens when it has been open ?? Or have you dropped it at the beach and got sand or grit in the lens ??. If it is a lens problem it will have to go back to the service agent for repairs - ther is nothing you can adjust inside unless you are a camera technician
Nov 07, 2009 | Olympus FE-340 Digital Camera
Camera lens broken
well i guess you can try any camera shop to have it sent out for repair, but get a quote first. Often it is cheaper to replace the camera rather than have it repaired. If you have insurance you can make a claim for the repair depending on replacement cost
Please rate our help to keep the service online
Aug 28, 2009 | Olympus FE-210 Digital Camera
Olympus FE-340 camera i turn on the power the lens goes in and out 2 or 3 times and the view is blurry in the view finder. The zoom feature has no effect when pushed to the wide setting and will turn off...
your lens may be damaged...your zoom assignments may need to be realligned if there are no broken parts. If there are broken parts in your lens it may be better to get a new lens
Aug 10, 2009 | Olympus FE-340 Digital Camera
Dec 07, 2008 | Olympus FE-220 Digital Camera
Problem with fe-210
Lens gears are probably broken off, or other problem with lens. Will need to replace lens, or may possibly be repaired. I've repaired a few lenses with gears broken off, by replacing broken off posts with similar size plastic pieces(drilled holes and super glued in place, being very careful). Still working months after repaired. Olympus repair shops can replace anything needed, but at a HIGH price; sometimes cheaper to replace camera than to have them work on it.
Jun 08, 2008 | Olympus FE-210 Digital Camera
Broken Lcd panel
Broken LCD screen is quite easy to replace on the FE-170 and FE-210. I have purchased cameras with bad lens but good LCDs on ebay pretty cheaply( compared to having Olympus repair camera).
Mar 01, 2008 | Olympus FE-170 Digital Camera
FE 170 OLYMPUS digital camera
The lens need to be replaced or repaired. It is not fully extending. It may be that one or more of the plastic gears or plastic rods that hold the gears in place, are broken. I repaired two plastic rods in my lens, by drilling holes for new plastic rods,(I cut plastic rods from a plastic toilet bowl chain!!! It fit inside the gears perfectly), and super glue the rods in place. Replaced gears, put camera back together and BAM in worked! Nothing like a perfectly working refurbished rig job. Camera takes great pictures to this day.
Nov 27, 2007 | Olympus FE-170 Digital Camera
Olympus FE-25 Digital Camera Logo
32 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
