Question about Jandy LAARS LX400 - NATURAL GAS, DIGITAL READ-OUT, LOW NOX
Secutron MR2400 fire panel read out trouable output
I have a 1989 Ford f150 xlt lariat 5.0L 4x4 can't figure out if it is high output usually it's stamped HO on motor but may have been changed seems to fire better with the high output firing order
Post the eight digit of your VIN NUMBER. Both E and T are listed for a Mustang GT HO 302, although the trucks may be coded differently .
Dec 05, 2015 | Ford Cars & Trucks
How do I wire a 220V AC siren to a manual callpoint and a converntional fire control panel which has a bell output of 24v DC?
Wire a RIB 24vdc relay module to the bell output. Use dry contacts on the module to either trip a low voltage contactor, or wire to dry contacts on RIB module (check relay current ratings, do not exceed). Functional devices sells the RIB modules.
May 07, 2015 | Home
How can I wire a 220volts sire to a fire control panel which has a 24volts bell output?
You will need to purchase a relay capable of handling 220v with a minimum of 5A. Wire the 24v bell output across the COIL of the relay, then wire the relay commutator connections to switch power, so that when the relay receives 24v, it switches supply power to the 220v siren.
May 07, 2015 | Heating & Cooling
JVC DLP MOD#HD55G466 what is the voltage from power supply to ballast and into the lamp.I have no voltage to the lamp could it be ballast?
Ballast board gets voltage from power supply connector CN90BL and volts readings are as follows:
Pin-1 = 380V DC
Pin-2 = Ground
Pin-3 = 15V DC
and output of ballast board would be 12,000 volts AC that goes to lamp to generate spark in its electrodes to produce high bright light.
If you get volts on input of ballast board but still lamp does not fire up then ballast board is not working.
Ballast board part number is QAL0765-001 and available with tv-part.com for $125
Hope these info will help you.
Thanks.
Nov 16, 2010 | Televison & Video
Where can i find info on a windsor elite gas fire?i need to know if it is less than 7kw output
Hi these fires are old not made now there is a data badge on the front panel that lifts off but they are only about 30,000 btus
Feb 08, 2010 | Sigma 1.133708 - Series 1300 Windsor Elite...
Where to connect fire alarm to a combination starter with a hand/off/auto/switch
The fire alarm (usually an open contact, held closed during healthy operation) MUST go in series with the supply to the switch. This is normally incoming to a terminal which is linked between the hand and auto positions. If this is a full control panel, the fire alarm connection SHOULD be used to drop out the entire control circuit. Can you supply wiring diagram?
Sep 13, 2009 | Heating & Cooling
Honeywell xls1000 fire panel sounding
It will probably keep doing that until u run a maintenance routine on the smokes from the panel. Look in the panel main menu and you should find a maintenance (or similar entry). Run it.
Jan 17, 2009 | Electrical Supplies
Jandy LAARS LX400 - NATURAL GAS, DIGITAL READ-OUT, LOW NOX Logo
69 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
