Question about HP OfficeJet R80xi All-In-One InkJet Printer
Won't print or copy (looks like it's out of ink or cartridge is jammed)
I love my printer/copier, but is it time for a new printer?? The black cartridge acts like it's jammed. I tried two new cartridges and get nothing but a few spots of ink, whether copying or printing. Any guess where the problem is??
  • Anonymous May 09, 2009
    I tried printing a test page, but no luck. At this point I'm getting nothing either when printing or copying, and I've tried 2 new cartridges...what else could it be?
  • 975 Answers
If you have the program of printer install to your comp ? then run the maintenance program , that will CLEAN , ALIGN , AND PRINT A TEST PAPER , AJ
Posted on May 08, 2009
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
Won't print black
TRY CLEANING THE INK CARTRIDGE. If it doesnt work, go to service center with the printer.
Jun 30, 2012 | BROTHER INTERNATIONAL CORPORAT BROTHER...
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
Black ink cartridge is new but not printing
Was the code of the cartridge you put is correct? if not then replace it.if it is right, then check the nozzles, the printer heads and clean. some printer is equipped with cleaning tools software that might help you.
Jan 20, 2010 | Canon BubbleJet i320 Printer
Black ink cartridge
You all need a new printhead. If the eyes on the demo sheet (copy and photo at the same time) are coming out all white and they look like zombies the black text isn't working properly. Try cleaning the printhead. If that doesn't work, call kodak, you need a new printhead.
Sep 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Black ink cartridge
i called the same number as mshanklin and had the same offer of print head and replacement cartridges. they better work! :)
Sep 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
5100 will not copy
call the tech support finally got a number....
Troubleshooting with the Kodak tech (1-800-421-6699 US & Canada)
my printer would not print black and copy was almost blank....they are sending me a new
printhead....it looks like there are alot of issues with this printer.
but I love the value
Sep 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
HP OfficeJet R80xi All-In-One InkJet Printer Logo
95 people viewed this question
Seeker5211
Seeker5211
