Question about Craig Electronics CHT912 Bluetooth TV Sound Bar System
Sound will play for a few minutes then cut out using line in connection
42 INCH LG PLAYS GOOD FOR A MINUTE OR TWO THEN SPLITS OFF INTO SCREENS NO SOUND
a heat sensitive component
the only way to find it is with freeze spray and a lot of patience
Aug 11, 2014 | LG Televison & Video
Speakers cut out after 7 minutes
It sounds as if something is not grounded properly. Check your wiring and make sure all connections are made.
Feb 12, 2014 | Cars & Trucks
When on FM tuner, stereo stops playing after a few minutes
Right then sounds like the connection from the aerial lead into the receiver - check out the socket where the aerial plugs into!
Is it loose at all or could there be a bad connection inside the unit.
Get the cover OFF and investigate yourself before you rush down to that very friendly repair man along the street.
Jan 05, 2014 | Denon DRA-365R Receiver
While using Skype with my Toshiba laptop and webcam the sound will all of a sudden cut out. I have to end call and then click video call again to get the other party can hear me and after a few minutes,...
1. this could be several reason why the sound cut out when using skype
2. check the hard drive capacity
3. you may need more RAM ( random access memory). If you are at minimum this may not be enough to complete the VOIP ( voice over IP)
4. this could be the connection with the skype recipient.
5.check your skype settings
6.check the sound card in your laptop ( drivers etc)
7. check the speakers of the laptop the may be malfunctioning or the earphones if used.
Jun 13, 2011 | Computers & Internet
While watching our set, after a few minutes, the picture on the screen condenses into a single line. You can stil hear the sound. Is the tube shot?
I would look for bad (cracked ring around pins) solder connections at the vertical output IC. Do not let play long with the line present or it will burn a trace across the face of the picture tube and you will never get it out.
Jan 29, 2011 | Toshiba MD20F51 20 in. TV/DVD Combo
Sound keeps cutting out. Have to reboot to get back. Please help
you can try uninstalling and reinstalling the drivers,or also try to update it
Jun 14, 2010 | Bose Companion 5 Multimedia Speaker System...
My AKAI PDP4273M 42" Plasma has thin horizontal lines that flicker across the screen and then the picture jumps and flashes red and green distortions on the screen acts like interfearance of some sort if i...
This sounds like a loose solder joint, or overheated component. I know this may sound like a **** question, but have you tried tapping the TV to see if it goes away? If it does, you will need a tech to re solder the loose component. I have also seen this type of line and color bleed problem, believe it or not from poor cabling or loose connections.
Mar 09, 2010 | Akai PDP4273M Television
Turns on and works great...after about 10 minutes it doesnt work.
it is probably because your xbox is over heatng and you have a bad or loose wire in your xbox, try to put a fan facing the back of it before u turn it on
Jun 04, 2009 | Microsoft Xbox 360 Console
Sound cuts out every so often when using Coax Digital In
DI cables have little end caps, make sure they are removed
Mar 04, 2017 | Audio Players & Recorders
solution to Both our problems is this, call Philips, "it just so happens that we have a rapid replacement program for this particular system"-"there seems to be an internal electrical problem", so I'm sending it back to them.......
Dec 12, 2007 | Philips HTS-3555 System
Craig Electronics CHT912 Bluetooth TV Sound Bar System Logo
Top Craig Audio Players & Recorders Experts
odiegh
odiegh
 Grubhead
Grubhead
Gyula Lacz
Are you a Craig Audio Player and Recorder Expert? Answer questions, earn points and help others
