Question about Jacuzzi Refresh Hygiene Toilet Seat Round EU44959
Bowl fill tube comes loose and squirts all over the house
  • 2,113 Answers
You can stick the tube all the way down if it is long enough or build your own holder. If you replace the ballcock with a modern one they come with all those parts to hold the hose down
Posted on Nov 28, 2013
How do I fix a pflotec FP4012 08 pump pressure switch tube that is disconnected and squirting water
Push it back onto nipple-should hold rarely come off-change tubing if too loose.Put a small clamp.easy as pie.
Sep 14, 2014 | Plumbing
Water squirts from tank while filling
Take lid off and check that the fill tube is in place. If so flush with lid off to see were the water is squirting from, be prepared to clean up water...If you can, do a slight flush. If there is water coming from any where but the bottom of fill valve and the fill tube you may need to replace the fill valve. In my experience, the fill tube is dissconected.
For Diagram
http://www.askmehelpdesk.com/attachments/plumbing/19906d1242687133-shut-off-valve-under-toilet-doesnt-work-fluidmaster-20ballcock.gif
Jul 06, 2010 | Kohler K-3386-0 Rialto one-piece...
Tiolet not flushing right. Water not coming down the side of the bowl when flushing and 90 percent of the water is gone from the bowl.
1- Check ports out under rim all round bowl.
2-Check tank fill level for required amount to with in 5/8" to top of over flow tube.
3-Make sure 1/4" fill tube is connected to over flow tube. From fill valve to overflow tube.
Below is a few details to go by I hope will be helpful for you to take care of this problem.
Under the rim of the bowl check the ports and make sure they are not stopped up. You can open them up with nail or pin to clean out ports.
Next check tank level and make sure the fill valve has a line run from it to top of the overflow tube. This line allows water to goe to bowl and tank to fill required amount needed.
Water in tank should be within 5/8" to top of over flow tube.
Jun 22, 2010 | Pegasus Technologies Two-Piece Round...
I bought 3 cadet 3's a monthe ago and 1 of them has severe splash back problems since it was installed. The only difference that I see between them is that the water level in the bowl is extremely low in...
The fix for this issue is the water flow tube most likely came out and is running into the tank instead of the overflow tube. Here's a picture of what it should look like. The tube must come out during shipping. Once I put the tube back in no issues with splashing! And until I figured this out I was about to return it to Lowes!
Jun 20, 2010 | American Standard Cadet 3 Right Height...
Low water level in bowl after flushing
The small black tube that goes into the overflow is used to fill the bowl after flushing. Would check to make sure that water is coming out of that tube at full force or if its coming out at all.
May 11, 2010 | Eljer & Elongated Toilet Bowl
BRand new elongated Cimarron shoots water out of bowl durng flush
Is the fill line in the tank loose? Does it just shoot water into the tank itself? I had this issue until I realized the while fill tube is supposed to be pushed into the black cylinder/small plastic tube in the middle of the stopper assembly. After i pushed the line into the tube, the bowl would always only fill a little bit. Now it fills almost a 3rd of the way up the bowl and doesn't bubble during flushes.
May 09, 2010 | Kohler Cimarron Comfort Height elongated...
Our Toto bowl does not fill up enough after flushing unless the lever is held down. What do I do to fix it? We have well water and a bit of mineral does build up on the fill tube.
The only adjustment available is to control how full the tank will be for the next flush. The water that runs down into the bowl after flushing comes through the same valve that fills the tank, so the problem (and solution) is entirely with the amount of water that runs into the bowl while the tank is filling. The tank is filling sooner than enough replacement water can run into the bowl. Make sure that the tube (usually a 1/2 inch rubber tube) that runs from the float valve to the pipe that fills the bowl (usually a 1 inch pipe with an open top) is actually delivering all of it's flow down that pipe. If the flow of water being delivered by that tube is slow, you will have to find and eliminate the restriction. You might be able to pull of the rubbber tube off of the float valve and stick a small drill bit (just using your fingers, not a drill) into the fitting where you pulled off the tube.
Mar 08, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
Not enough water in the bowl after flushing
I don't know what kind of toilet you have, but if it has a tank, then probably the tube that squirts water down the pipe into the bowl has come out. Take the top off the tank and as you watch, flush the toilet and make sure water is going thru the tube down into the pipe. good luck
Mar 07, 2010 | Eljer & Patriot& Elongated Toilet Bowl
Bowl does not fill after flushing
Check the fill line in the tank and make sure it is connected from fill valve to overflow tube. After you flush the toilet it fill's the bowl and tank.
It should be a line about 1/4 ' in size coming from fill valve to overflow tube.
Dec 28, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Bowl will not fill.
There is usually a small tube on the top of the ballcock or the fill valve in the toilet tank. The tube should be clipped to the top of the flush valve pipe so that the water will flow into it. Should the small tube become loose and fall off of the clip, the refill water will not make it back into the bowl.
Aug 09, 2009 | Home
Jacuzzi Refresh Hygiene Toilet Seat Round EU44959 Logo
65 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
