Question about Toshiba Satellite P755S5215 PC Notebook
Battery light flashes
My laptop will not charge "while it is on". It must be either off, sleep, or in hibernate mode for it to charge. A pinkish light flashes if it's not fully charged when on.
  • Toshiba Master
  • 7,993 Answers
Well, if you are using the laptop it is using the power it needs. Any surplus power supplied by the adapter will go towards charging the battery. If you want to charge the battery fast do not use the computer.
You can also use the laptop but not at full power. It is your choice, but you cannot have your cake and eat it too.
Posted on Nov 27, 2013
  • 232 Answers
SOURCE: Toshiba A135-S4527 laptop ** Battery not charging!
Check the power input jack soldered connections for cracks, resolder them as necessary.
Posted on May 15, 2009
  • 36 Answers
SOURCE: Laptop stuck in sleep / hibernate mode??
Try holding the power button down for at least 10 seconds, that should turn off the laptop completely. Then press the power button again to turn it on. Hopefully it will boot up.
Posted on May 19, 2008
  • 327 Answers
SOURCE: My laptop battery won't hold any charge
its the connectors to which the battery gets connected internally that r either loose or boken from internally needs replacement or a minute reparing.
Posted on Dec 18, 2008
sijudoniston
  • 134 Answers
SOURCE: I can't get it out of hibernation mode
Hold the poweroff switch for a while and release.Then disable the hibernation mode in the power options.
Thanks
Siju.D
Posted on Oct 30, 2009
  • 124 Answers
SOURCE: TOSHIBA SATELLITE M45-S165 won't charge Battery.
it could be possible that changing the dc jack at the back may fix the problem however it could be a faulty new battery as ive had a few copies (not original) which would work for a week or so then die or others which wouldnt work at all, i finaly splashed out on a new original battery and it hasnt let me down and i bought it over a year ago.
Hope this helps
Posted on Apr 19, 2010
Testimonial: "Thank you. I will contact the battery supplier."
My Acer Aspire 7750g-6857 will only charge when in sleep, hibernate, or shut off. When i plug the charger in, the power light will flash and it won't charge. Please help..
try to remove the battery, plugged into charger and see what does the icon shows. right click the icon and select power option try to restore all settings to default. if this would help.
thanks
Mar 31, 2014 | Acer Aspire Computers & Internet
Blinking light
All the time, or only when in Sleep/Hibernate mode? Is the battery charging properly? A bit more info. Shut down Sleep and Hibernate to verify.
Jul 03, 2013 | HP Compaq 6910p Notebook PC PC Notebook
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
When laptop charging in off position and if i connect usb pen drive, ext. HDD, etc. these are on and flashing
Is the laptop off or Hibernating? Sleeping? Open the Control Panel, Power Options, Set to High Performance, open Advanced Power settings, set Hibernate and Sleep to Never. Shut down the laptop at the Start Menu. If the AC cord is plugged in the battery will charge. Nothing else should work.
Jan 16, 2013 | Lenovo 3000 C200 CM 520 1.6G 512MB...
Hi. I have a HP Compaq 6820S, Intel Pentium T7250, 2 Gb RAM, 160 Gb HDD, i have a problem, Laptop won't charge battery. I let the laptop in sleep mode, around 7 days, when i come back, battery was 0%,...
try a new battery yet? (brand new fresh)
sleep mode. so you want it to run for 7 days in sleep.
ive no idea how long this laptop runs in sleep
and hibernate is longer.
no idea at all.
you do know that the speed features are programmable
right?
including what chips do and do not go to sleep'
like USB ports, WIFI, and all wake on , features. like Ethernet chip.
and more.
why not just turn it off, and let the battery last longer..
this mode sleep kills batteries faster. way faster.
leave it plugged in all the time to the wall pack.
so the battery never drains unless you need to use it, on battery.
Jul 18, 2017 | HP Compaq 6820s Notebook
Laptop wont wake from sleep or hibernation
1. you will need to go into you BIOS settings for the mother board to disable the sleep mode.
2. You also have a " sleep mode" in your Windows environment.
Check how to in the "help and support" link at the start button or Windows Orb ( for Windows 7)
Apr 15, 2010 | HP Pavilion dv2000t Notebook
Wont turn one, power light flashes 3 times
I will need more information here but it seems that either the battery needs a charge or the power adapter has failed.
2. or the unit is in the sleep or hibernation mode.
Sep 29, 2009 | Compaq Presario CQ60-220US PC Laptop
Won't power up. Turn on and won't start up.
sound like the memory modules possibly got lose or have bad contact remove and reinsert memory modules if that dont work you may have a weak battery and it may not be charging the worst senerio is motherboard going bad good luck!
Sep 01, 2009 | Toshiba Satellite A200-16J01D Notebook
Computer was in hibernate or sleep mode when the battery drained. Now, will not boot, appears to come out of sleep mode but only shows TOSHIBA splash screen and the hard drive lights do not activate. F8...
Dear! take display properties use tab ans select screen saver then click on power and use tab again select hibernate if it is enable check again it and disable now. After that your computer will not go in sleep or hibernate mode.
Thank You
Jul 26, 2009 | Toshiba Satellite M100 Notebook
A fully charged Toshiba Satellite M305D-4831 has a nasty tendency of running the battery down when it is put to sleep and hibernation. It is worse when in sleep, as I lose nearly half of the charge in...
If you go to control panel + power settings you can configure and adjust how your power gets distributed when in sleep mode etc. This may not totally fix your issue as it will alleviate the loss of power. I would first see what type of life the battery is supposed to have and if you are not satisfied your best bet is to replace the battery with a longer life. Goof luck and please let me know if you need any assistance with that.
Mar 11, 2009 | Computers & Internet
Open Questions:
Toshiba Satellite P755S5215 charging issues Ok, to be blunt and straight to the point, my laptop will not charge "while it is on". It must be either off, sleep, or in hibernate mode for it to charge. A pinkish light flashes if it's not fully charged when on. I bought a new charger, a new battery, still the same issue. I updated the Bios and continue looking for updates to solve this problem, but nothing helps. I'm good with electronics, but I just can't seem to get this laptop to charge. So for the last year, all I've been doing was making sure the battery stays fully charged, because if I don't and I don't notice that the battery is being drained then I have to wait HOURS for the battery to charge all the way or I just switch the next battery til something goes wrong with that. I also noticed that when on the computer the battery would start draining, and it seemed like it was reacting to me using softwares on my computer. Not sure which softwares it could be though. But I've basically tried everything I could think of. I did have a little issue with the power port, but I fixed that myself. I took the the laptop apart and put the port back in place because it was loose. My original laptop charger had broke and I struggled keeping the battery charged, but I didn't have this issue until I got a new charger if I remember correctly. I don't have enough money to pay Toshiba to fix it, they gave me the run around when I called them which made me feel like I couldn't trust them when they didn't even know what they was doing or talking about. They talked like they were beginners and told me everything a 8 year old child would know. Check the battery, charger...still nothing? Send it in, we'll look at it, oh and we're not liable if everything is erase. I don't trust none of that. Your property is not safe with a company who says your memory may be erased. If that's the case, then you contact the owner and let him know, you may need to erase the harddrive before doing so, and they'll let you know, go ahead or not. I wouldn't recommend Toshiba laptop products, because I've seen a lot of ppl complain about their customer service and how bad the products are messing up. How do you not know how to fix your own products? A couple of people have the same problem as I and they said Toshiba said they're not sure on what the problem is and to send it in. If it's not fixable then I'll just sell it and never buy a Toshiba laptop again, and recommend people not to buy any of their laptops. I don't want people to go through the same situation I am.
Jul 13, 2012 | Toshiba Satellite P755S5215 PC Notebook
Toshiba Satellite P755S5215 PC Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
