Question about Casio Fx-991es Scientific Calculator
The below calc button is not responding - Casio Fx-991es Scientific Calculator
  • Casio Master
  • 8,064 Answers
The calculation may be taking too long and you got impatient. To reduce the time it takes to calculate some expression or find a root you can make better guesses (initial values), or choose better limits to an integral, or divide the integral in two if integrand symmetrical. If you can select the tolerance (error you are willing to accept), increase it: Instead of taking epsilon =1E-9, take epsilon=1.E-5. But that depends on the context of the calculations. You be the judge.
Posted on Dec 21, 2013
2 Suggested Answers
  • 102366 Answers
SOURCE: WHAT IS THAT BUTTON BELOW THE CALC BUTTON
It's the fraction button. It lets you enter a fraction as a numerator and a denominator.
Posted on Nov 27, 2013
EL9300 not responding after a battery change. Only a down arrow is displayed on screen on top of screen
Just had this EXACT problem on a Sharp EL-9200C. I got the down arrow to go away and then the calculator functioned like normal. Here's how: I got a ball point pen and rapidly activated the reset button on the back, then rapidly pressing the CL key... probably about 45-50 times, but eventually it cleared all the memory out and the calc was able to boot up. This was after replacing the batteries multiple times and trying every key and every 2ndF key. I feel like the master of the universe now!
Mar 07, 2015 | Sharp El-9200c Scientific Graphing...
Nov 27, 2013 | Casio FX-115ES Scientific Calculator
How do you calculate sec174?
SEC, CSC & COT are the INVERSE of COS, SIN & TAN and are usually require hitting the "2nd F" or "Func" key of the calc to make:
SIN button work as COSEC,
COS button work as SEC
TAN button work as COT
Formulas are below:
sec x = 1
cos x
cosec x = 1
sin x
cot x = 1 = cos x
tan x sin x
Feb 05, 2013 | Sharp EL531 Scientific Calculator
TI connect DeviceExplorer not responding
Hi
You can try and clean the I/O port just blow air inside if it will not help you can try to install the Os again , take all 4 batts wait 5 seconds put them back take one batt out press and hold the del key and put back the battery and then press the on button the calac will go off this should rest the calc if it will not help take out 1 batt pres and hold the del put back the batt and connect the calc and try to install the Os i hope it will help
Jul 22, 2012 | Texas Instruments TI-84 Plus Silver...
My TI84 does not respond except for sin
Hi
if you can open the calc and check if you see some spots of liquid or acid that leak from the batter if yes take the main circuit out and clean the contact if it will not help its an hardware failure
this can be fixed let me know if you want to fix
Jun 14, 2012 | Texas Instruments TI-84 Plus Calculator
How to use the calc-clean button
Calc-Clean function
The Calc-Clean function removes scale and impurities.
To do so, set the steam control to position '0', set the temperature dial to 'MAX', and fill water tank up to the 'MAX' level. Then heat up the iron until the pilot light on the handgrip goes out.
Remove the mains plug from the wall socket and hold the iron horizontally over the sink. Then press and hold down the 'CALC CLEAN' button.
Move the iron forwards and backwards while boiling water/steam squirt from the holes in the soleplate to wash away impurities/scales.
When the water tank is empty, heat up the iron to dry it.
Finally move the iron to and fro on a piece of cloth to dry the soleplate. Repeat the process if necessary
May 05, 2009 | Philips HI-296 Iron
Casio Fx-991es Scientific Calculator Logo
63 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
