Question about BCI Spectro 2-10 Pulse Oximeter
TO RESET THE SPECTRO 2 10 - BCI Spectro 2-10 Pulse Oximeter
What oils do i need to change in my 2003 wideglide
I like mobil 1 20-50 ..engine.,,,,,. tranny spectro platinum or red line gear oil .,,,. primary h/d formula +... ride safe,,,,,
May 07, 2011 | 2003 Harley Davidson FXDWG Dyna Wide Glide
What type of oil for the primary cover on 05 fat boy?
I like hd formula + for primary's but any non synthetic is OK 10-30..oil.. spectro makes a good oil for that 2
Apr 07, 2011 | 2000 Harley Davidson FLSTF Fat boy
When cold very hard shifting into second gear. Any solutions out there
Change the trans oil to a full synthetic 75-140, Golden Spectro is my recommendation. That may help, that stuff is great.
Jun 08, 2010 | 2000 Harley Davidson FXSTD Softail Duece
Warning. Color sensor may not be working properly. If problem persists call HP.
The listed error message is accompanied by the error code "58:10"
This error code can mean one of two things. Either the color sensor (the spectrophotometer) is malfunctioning - in which the error code would persist and a technician would need to be called. Or the sensor picked up a piece of lint or dust when doing its self-calibration - in which case it would come up as a single occurrence.
Here is a follow-up suggestion if there was any further concern. With the following steps, the spectro instrument (along with the print head) can be inspected. To do that, select "Replace print head" from the front panel and then turn of the power (hard switch on the back of the machine). With the printer off, open the tinted glass and slide the carriage over. This should allow the carriage head with spectro instrument to be brought into view for inspection of an lint or dust, etc. To restart the printer, just close the tinted glass and power the printer back up from the hard switch.
Nov 02, 2009 | HP Designjet Z2100 InkJet Printer
What is the premix oil ratio i should use on my KTm 2004 250 exc 2 stroke and what kind of oil should i use?
32:1
Any pre-mix synthetic.
Maxxima is good
Golden spectro
Or even what the factory recommends.
Aug 27, 2009 | 2004 KTM EXC 250 Racing
Why the Pelco spectro mini PTZ camera getting stuck(not rotating)
Normallay when getting stuck in Mini dome, we found 2 common problem.
1. Take out the cover and test rotating. Dome are deflect and causing resistance between camera dome and bubble.
2. The 2 screw are too tight. Loosen abit and try rotate.
Jun 03, 2009 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
Air filter
Well I use PJ1 Oil and Cleaner so I just spray it on and it sticks really well... When you have to pour the oil on try pouring a little into a ziplock baggie and then put your filter in there and seal it, and just rub the filter in the oil and mess with it for a while and soon the oil will have cover all of the filter. or You can put a little into a bucket, and just dip your filter in it and mess with it until it is lightly covered. You'll get a little messy doing it this way tho...,,,
Nov 10, 2008 | 2007 HM CRM 125R
Air filter
Nov 10, 2008 | 2004 HM CRM 125
Air filter
Nov 10, 2008 | 2007 HM CRE F290X I
Oil type choice
For the best results use a full synthetic oil - not a synthetic blend. When you change oil filters add an Engine Sentry to the filter.,,
Nov 10, 2008 | 2003 Aprilia RSV 1000 R Edwards
BCI Spectro 2-10 Pulse Oximeter Logo
26 people viewed this question
Top BCI Computers & Internet Experts
David Payne
David Payne
Are you a BCI Computer and Internet Expert? Answer questions, earn points and help others
